15 years agoSopc Help
hi again, I'm using a SDRAM controller in SOPC. but things are not working right. Failing paths, buffer of templates are getting full , ... I'm using master write and master read ...
15 years ago --- Quote Start --- Sopc builder should have generated automatically a .sdc file for your system. You must include it in your Quartus project. --- Quote End --- You have to enable the settings for that? Cauze i can't find it in the main directory. --- Quote Start --- Also make sure your checked the "Timing driven synthesis" in Analysis&Synthesis settings and follow the other guidelines reported by timing optimization advisor. --- Quote End --- I did. --- Quote Start --- Final note: probably this is not your current problem, but usually you must drive the sdram clock pin with a phase lead relative to clock used by sopc system. --- Quote End --- Probably you need to apply that in the sdc aswell. How?
