--- Quote Start ---
You have to enable the settings for that? Cauze i can't find it in the main directory.
--- Quote End ---
AFAIK sopc builder generates the sdc file by default, together with the .qip file which contains the hdl file references. At least this is true for the Quartus version 9.0sp2 I use.
Did you select TimeQuest as time analyzer?
Regarding the sdram clock phase, I remember it must be calculated somehow like this (although I'm not completely sure):
- pre-compile the project with 0 phase shift
- search the PLL offset in the timing analysis report
- search the sdram clock combinatorial delay from pll output to clock pin
- the sdram clock phase lead must be set that the sum of pll offset and combinatorial delay is a bit longer than the sdram setup time
- recompile the Quartus project
I use the same SDRAM as yours and EP3C40: with Fclk=100MHz I set dram clk phase = -27degrees = -0.75ns. As a rule of thumb you can also try -0.75ns which for your 148MHz would mean a phase lead of 40deg.
