Soft LVDS IP simulation for MAX10
I am working with Intel Max10 - 10M50DAF484C6GES for one of my applications, which has the requirement to transfer and receive the serial data (SERDES-LVDS) with data rate of 100Mbps. I am using individual IP Soft LVDS IP cores for TX and RX functionalities with 8 bit single channel and i am not using external PLL configurations. I am passing the parallel 8 bit data to TX_in from the testbech and passing the data to the RX_in through port mapping the TX_out pin from the test bench.
RX_out is "0" and not changing as wrt to input. I am attaching the waveform for the same with the test bench code. I am referring " MAX 10 High-Speed LVDS I/O User Guide", UG-M10LVDS
2015.05.04 document.
Can you please help me what changes has to be made for RX_out to change as per input.
The following is the configuration details of IP cores,
TX IP configurations:-
Power supply mode: Dual supply
Functional Mode: TX
Number of channels: 1
SERDES Factor : 8
Datarate: 100 Mbps
Input clock frequency: 50
TX_outclock division factor :8
Rx IP configurations:-
Functional Mode: RX
SERDES Factor : 8
Datarate: 100 Mbps
Input clock frequency: 50 MHz
following is my Test bench code:
Library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use IEEE.numeric_std.all;
entity SERDES_RX_TX_TB is
end entity SERDES_RX_TX_TB;
Architecture RTL_TB of SERDES_RX_TX_TB is
Component SERDES_RX_TX is
port (
Top_tx_inclock : in std_logic := '0'; -- tx_inclock.tx_inclock
Top_tx_outclock : out std_logic; -- tx_outclock.tx_outclock
Top_tx_coreclock : out std_logic; -- tx_coreclock.tx_coreclock
Top_pll_areset : in std_logic := '0'; -- pll_areset.pll_areset
Top_tx_in : in std_logic_vector(7 downto 0) := (others => '0'); -- tx_in.tx_in
Top_tx_out : out std_logic;
Top_rx_inclock : in std_logic := '0'; -- rx_inclock.rx_inclock
Top_rx_outclock : out std_logic; -- rx_outclock.rx_outclock
Top_rx_in : in std_logic := '0'; -- rx_in.rx_in
Top_rx_out : out std_logic_vector(7 downto 0)
end component SERDES_RX_TX;
signal TB_tx_inclock : std_logic := '0';
signal TB_tx_outclock : std_logic;
signal TB_tx_coreclock : std_logic;
signal TB_pll_areset : std_logic := '0';
signal TB_tx_in : std_logic_vector(7 downto 0) := (others => '0');
signal TB_tx_out : std_logic;
signal TB_rx_inclock : std_logic := '0';
signal TB_rx_outclock : std_logic;
signal TB_rx_in : std_logic := '0';
signal TB_rx_out : std_logic_vector(7 downto 0);
signal TB_rx_data_align : std_logic := '0';
signal TB_rx_data_align_reset : std_logic := '0';
signal TB_Cntr : std_logic_vector (7 downto 0) := (others => '0');
constant CLK_PERIOD : time := 20 ns;
--constant CLK_PERIOD_2 : time := 20 ns;
begin
UUT: component SERDES_RX_TX
port map (
TOP_tx_inclock => TB_tx_inclock,
TOP_tx_outclock => TB_tx_outclock,
Top_tx_coreclock => TB_tx_coreclock,
TOP_pll_areset => TB_pll_areset,
TOP_tx_in => TB_tx_in,
TOP_tx_out => TB_tx_out,
TOP_rx_inclock => TB_rx_inclock,
TOP_rx_outclock => TB_rx_outclock,
TOP_rx_in => TB_tx_out,--TB_rx_in,
TOP_rx_out => TB_rx_out
Reset_Gen: Process
begin
--wait for 100 ns;
TB_pll_areset <= '1';
wait for 200 ns;
TB_pll_areset <= '0';
wait;
end process;
Clk_Gen: Process
begin
TB_tx_inclock <= not TB_tx_inclock;
TB_rx_inclock <= not TB_rx_inclock;
wait for CLK_PERIOD / 2;
end process;
Data_feed: process (TB_tx_inclock)
begin
if TB_pll_areset = '1' then
TB_Cntr <= "00000000";
elsif TB_tx_inclock'event and TB_tx_inclock = '1' then
for i in 0 to 9 loop
TB_Cntr <= TB_Cntr + '1';
end loop;
end if;
end process;
TB_tx_in <= TB_Cntr;
end RTL_TB;
I have also attached the simulation waveform for the reference.
Thanks in advance.
- Ash_R_Altera
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- Ash_R_Altera
Can you try inverting the rx_inclock signal to align it differently with the rx_in data?
- ArjunBK
- Ash_R_Altera
Have you applied any phase shift in the PLL Settings tab, "Desired receiver inclock phase shift" drop-down menu?
- Ash_R_Altera
I am able to get the rx_out signal with your testbench and the settings that you mentioned.
Can you please try adding altera libraries during elaboration? You may use following command:
vsim -t ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L fiftyfivenm_ver -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm work.serdes_rx_tx_tb
- ArjunBK
- ArjunBK
Thank you for the reply. I tried with the command that you have provided in tcl command window, i am getting error . I have attached the screen shot for your reference "command.jpg". I could add the libraries using GUI, Assignments-> settings-> library (i have attached the screen shot for the same "library.jpg") but i see no change in the wave form, still RX_out stuck at "0".
