Soft LVDS IP simulation for MAX10
I am able to get the rx_out signal with your testbench and the settings that you mentioned.
Can you please try adding altera libraries during elaboration? You may use following command:
vsim -t ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L fiftyfivenm_ver -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L fiftyfivenm work.serdes_rx_tx_tb
Thank you for the reply. I tried with the command that you have provided in tcl command window, i am getting error . I have attached the screen shot for your reference "command.jpg". I could add the libraries using GUI, Assignments-> settings-> library (i have attached the screen shot for the same "library.jpg") but i see no change in the wave form, still RX_out stuck at "0".
