15 years ago
Simulation in Quartus 10
Hi all,
I was used to simulate my project with the simulation tool in earlier version of quartus but now, this tool is no longer available with the version 10.0 and I have to use ModelSim.
My questions are :
Is there an easy way like "vector waveform file" to initiate the simulation or do I have to do all the stuff with command lines?
Do you know a good tutorial to learn how to use ModelSim?
Thank you
    --       First part of the testbench file                           --
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    LIBRARY STD;
    USE STD.textio.ALL;
    PACKAGE test_project_vhd_tb_types IS
    -- input port types
    -- output port names
    CONSTANT output_test_name : STRING (1 TO 11) := "output_test";
    CONSTANT sync_out_name : STRING (1 TO 8) := "sync_out";
    -- n(outputs)
    CONSTANT o_num : INTEGER := 2;
    -- mismatches vector type
    TYPE mmvec IS ARRAY (0 to (o_num - 1)) OF INTEGER;
    -- exp o/ first change track vector type
    TYPE trackvec IS ARRAY (1 to o_num) OF BIT;
    -- sampler type
    SUBTYPE sample_type IS STD_LOGIC;
    -- utility functions
    FUNCTION std_logic_to_char (a: STD_LOGIC) RETURN CHARACTER;
    FUNCTION std_logic_vector_to_string (a: STD_LOGIC_VECTOR) RETURN STRING;
    PROCEDURE write (l:INOUT LINE; value:IN STD_LOGIC; justified: IN SIDE:=  RIGHT; field:IN WIDTH:=0);
    PROCEDURE write (l:INOUT LINE; value:IN STD_LOGIC_VECTOR; justified: IN  SIDE:= RIGHT; field:IN WIDTH:=0);
    PROCEDURE throw_error(output_port_name: IN STRING; expected_value : IN  STD_LOGIC; real_value : IN STD_LOGIC);
    PROCEDURE throw_error(output_port_name: IN STRING; expected_value : IN  STD_LOGIC_VECTOR; real_value : IN STD_LOGIC_VECTOR);
    END test_project_vhd_tb_types;
    PACKAGE BODY test_project_vhd_tb_types IS
                    RETURN CHARACTER IS
            BEGIN
            CASE a IS
             WHEN 'U' =>
              RETURN 'U';
             WHEN 'X' =>
              RETURN 'X';
             WHEN '0' =>
              RETURN '0';
             WHEN '1' =>
              RETURN '1';
             WHEN 'Z' =>
              RETURN 'Z';
             WHEN 'W' =>
              RETURN 'W';
             WHEN 'L' =>
              RETURN 'L';
             WHEN 'H' =>
              RETURN 'H';
             WHEN '-' =>
              RETURN 'D';
            END CASE;
            END;
                    RETURN STRING IS
            VARIABLE result : STRING(1 TO a'LENGTH);
            VARIABLE j : NATURAL := 1;
            BEGIN
                    FOR i IN a'RANGE LOOP
                            result(j) := std_logic_to_char(a(i));
                            j := j + 1;
                    END LOOP;
                    RETURN result;
            END;
            PROCEDURE write (l:INOUT LINE; value:IN STD_LOGIC; justified: IN SIDE:=RIGHT; field:IN WIDTH:=0) IS
            BEGIN
                    write(L,std_logic_to_char(VALUE),JUSTIFIED,field);
            END;
            PROCEDURE write (l:INOUT LINE; value:IN STD_LOGIC_VECTOR;  justified: IN SIDE:= RIGHT; field:IN WIDTH:=0) IS
            BEGIN
                    write(L,std_logic_vector_to_string(VALUE),JUSTIFIED,field);
            END;
            PROCEDURE throw_error(output_port_name: IN STRING;  expected_value : IN STD_LOGIC; real_value : IN STD_LOGIC) IS
            VARIABLE txt : LINE;
            BEGIN
            write(txt,string'("ERROR! Vector Mismatch for output port "));
            write(txt,output_port_name);
            write(txt,string'(" :: @time = "));
            write(txt,NOW);
            writeline(output,txt);
            write(txt,string'("     Expected value = "));
            write(txt,expected_value);
            write(txt,string'("     Real value = "));
            write(txt,real_value);
            END;
            PROCEDURE throw_error(output_port_name: IN STRING;  expected_value : IN STD_LOGIC_VECTOR; real_value : IN STD_LOGIC_VECTOR)  IS
            BEGIN
            write(txt,NOW);
            END;
    LIBRARY ieee;
    USE WORK.test_project_vhd_tb_types.ALL;
    ENTITY test_project_vhd_sample_tst IS
    PORT (
        master_clock : IN STD_LOGIC;
        N : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
        sync_in : IN STD_LOGIC;
        sampler : OUT sample_type
    END test_project_vhd_sample_tst;
    ARCHITECTURE sample_arch OF test_project_vhd_sample_tst IS
    SIGNAL tbo_int_sample_clk : sample_type := '-';
    SIGNAL current_time : TIME := 0 ps;
    BEGIN
    t_prcs_sample : PROCESS ( master_clock , N , sync_in )
    BEGIN
        IF (NOW > 0 ps) THEN
            IF (NOW > 0 ps) AND (NOW /= current_time) THEN
                IF (tbo_int_sample_clk = '-') THEN
                    tbo_int_sample_clk <= '0';
                ELSE
                    tbo_int_sample_clk <= NOT tbo_int_sample_clk ;
                END IF;
            END IF;
            current_time <= NOW;
        END IF;
    END PROCESS t_prcs_sample;
    sampler <= tbo_int_sample_clk;
    END sample_arch;
    --              First Part of the testbench file page2                      --
    LIBRARY ieee;
    LIBRARY STD;
    USE STD.textio.ALL;
    ENTITY test_project_vhd_check_tst IS
    GENERIC (
        debug_tbench : BIT := '0'
    PORT (
        output_test : IN STD_LOGIC;
        sync_out : IN STD_LOGIC;
        sampler : IN sample_type
    END test_project_vhd_check_tst;
    ARCHITECTURE ovec_arch OF test_project_vhd_check_tst IS
    SIGNAL output_test_expected,output_test_expected_prev,output_test_prev : STD_LOGIC;
    SIGNAL sync_out_expected,sync_out_expected_prev,sync_out_prev : STD_LOGIC;
    SIGNAL trigger : BIT := '0';
    SIGNAL trigger_e : BIT := '0';
    SIGNAL trigger_r : BIT := '0';
    SIGNAL trigger_i : BIT := '0';
    SIGNAL num_mismatches : mmvec := (OTHERS => 0);
    BEGIN
    -- Update history buffers  expected /o
    t_prcs_update_o_expected_hist : PROCESS (trigger)
    BEGIN
        output_test_expected_prev <= output_test_expected;
        sync_out_expected_prev <= sync_out_expected;
    END PROCESS t_prcs_update_o_expected_hist;
    -- Update history buffers  real /o
    t_prcs_update_o_real_hist : PROCESS (trigger)
    BEGIN
        output_test_prev <= output_test;
        sync_out_prev <= sync_out;
    END PROCESS t_prcs_update_o_real_hist;
    -- expected sync_out
    t_prcs_sync_out: PROCESS
    BEGIN
        sync_out_expected <= 'X';
    WAIT;
    END PROCESS t_prcs_sync_out;
    -- expected output_test
    t_prcs_output_test: PROCESS
    BEGIN
        output_test_expected <= 'X';
    WAIT;
    END PROCESS t_prcs_output_test;
    -- Set trigger on real/expected o/ pattern changes
    t_prcs_trigger_e : PROCESS(output_test_expected,sync_out_expected)
    BEGIN
        trigger_e <= NOT trigger_e;
    END PROCESS t_prcs_trigger_e;
    t_prcs_trigger_r : PROCESS(output_test,sync_out)
    BEGIN
        trigger_r <= NOT trigger_r;
    END PROCESS t_prcs_trigger_r;
    t_prcs_selfcheck : PROCESS
    VARIABLE i : INTEGER := 1;
    VARIABLE last_output_test_exp : STD_LOGIC := 'U';
    VARIABLE last_sync_out_exp : STD_LOGIC := 'U';
    VARIABLE on_first_change : trackvec := "11";
    BEGIN
    WAIT UNTIL (sampler'LAST_VALUE = '1'OR sampler'LAST_VALUE = '0')
        AND sampler'EVENT;
    IF (debug_tbench = '1') THEN
        write(txt,string'("Scanning pattern "));
        write(txt,i);
        write(txt,string'("| expected   "));write(txt,output_test_name);write(txt,string'(" =   "));write(txt,output_test_expected_prev);
        write(txt,string'("| expected "));write(txt,sync_out_name);write(txt,string'(" = "));write(txt,sync_out_expected_prev);
        write(txt,string'("| real "));write(txt,output_test_name);write(txt,string'(" = "));write(txt,output_test_prev);
        write(txt,string'("| real "));write(txt,sync_out_name);write(txt,string'(" = "));write(txt,sync_out_prev);
        i := i + 1;
    END IF;
    IF ( output_test_expected_prev /= 'X' ) AND (output_test_expected_prev   /= 'U' ) AND (output_test_prev /= output_test_expected_prev) AND (
        (output_test_expected_prev /= last_output_test_exp) OR
        (on_first_change(1) = '1')
            ) THEN
        throw_error("output_test",output_test_expected_prev,output_test_prev);
        num_mismatches(0) <= num_mismatches(0) + 1;
        on_first_change(1) := '0';
        last_output_test_exp := output_test_expected_prev;
    END IF;
    IF ( sync_out_expected_prev /= 'X' ) AND (sync_out_expected_prev /= 'U' ) AND (sync_out_prev /= sync_out_expected_prev) AND (
        (sync_out_expected_prev /= last_sync_out_exp) OR
        (on_first_change(2) = '1')
            ) THEN
        throw_error("sync_out",sync_out_expected_prev,sync_out_prev);
        num_mismatches(1) <= num_mismatches(1) + 1;
        on_first_change(2) := '0';
        last_sync_out_exp := sync_out_expected_prev;
    END IF;
        trigger_i <= NOT trigger_i;
    END PROCESS t_prcs_selfcheck;
    t_prcs_trigger_res : PROCESS(trigger_e,trigger_i,trigger_r)
    BEGIN
        trigger <= trigger_i XOR trigger_e XOR trigger_r;
    END PROCESS t_prcs_trigger_res;
    t_prcs_endsim : PROCESS
    VARIABLE total_mismatches : INTEGER := 0;
    BEGIN
    WAIT FOR 1000000 ps;
    total_mismatches := num_mismatches(0) + num_mismatches(1);
    IF (total_mismatches = 0) THEN
            write(txt,string'("Simulation passed !"));
    ELSE
            write(txt,total_mismatches);
            write(txt,string'(" mismatched vectors : Simulation failed !"));
    END IF;
    WAIT;
    END PROCESS t_prcs_endsim;
    END ovec_arch;
    --       Second part of the testbench file             --
    LIBRARY ieee;
    LIBRARY STD;
    USE STD.textio.ALL;
    ENTITY test_project_vhd_vec_tst IS
    END test_project_vhd_vec_tst;
    ARCHITECTURE test_project_arch OF test_project_vhd_vec_tst IS
    -- constants
    -- signals
    SIGNAL master_clock : STD_LOGIC;
    SIGNAL N : STD_LOGIC_VECTOR(31 DOWNTO 0);
    SIGNAL output_test : STD_LOGIC;
    SIGNAL sync_in : STD_LOGIC;
    SIGNAL sync_out : STD_LOGIC;
    SIGNAL sampler : sample_type;
    COMPONENT test_project
        PORT (
        output_test : OUT STD_LOGIC;
        sync_out : OUT STD_LOGIC
    END COMPONENT;
    COMPONENT test_project_vhd_check_tst
    PORT (
    END COMPONENT;
    COMPONENT test_project_vhd_sample_tst
    PORT (
    END COMPONENT;
    BEGIN
        i1 : test_project
        PORT MAP (
    -- list connections between master ports and signals
        master_clock => master_clock,
        N => N,
        output_test => output_test,
        sync_in => sync_in,
        sync_out => sync_out
    -- master_clock
    t_prcs_master_clock: PROCESS
    BEGIN
    LOOP
        master_clock <= '0';
        WAIT FOR 5000 ps;
        master_clock <= '1';
        WAIT FOR 5000 ps;
        IF (NOW >= 1000000 ps) THEN WAIT; END IF;
    END LOOP;
    END PROCESS t_prcs_master_clock;
    -- N
    t_prcs_N_31: PROCESS
    BEGIN
        N(31) <= '0';
    WAIT;
    END PROCESS t_prcs_N_31;
    -- N
    t_prcs_N_30: PROCESS
    BEGIN
        N(30) <= '0';
    WAIT;
    END PROCESS t_prcs_N_30;
    -- N
    t_prcs_N_29: PROCESS
    BEGIN
        N(29) <= '0';
    WAIT;
    END PROCESS t_prcs_N_29;
    -- N
    t_prcs_N_28: PROCESS
    BEGIN
        N(28) <= '0';
    WAIT;
    END PROCESS t_prcs_N_28;
    -- N
    t_prcs_N_27: PROCESS
    BEGIN
        N(27) <= '0';
    WAIT;
    END PROCESS t_prcs_N_27;
    -- N
    t_prcs_N_26: PROCESS
    BEGIN
        N(26) <= '0';
    WAIT;
    END PROCESS t_prcs_N_26;
    -- N
    t_prcs_N_25: PROCESS
    BEGIN
        N(25) <= '0';
    WAIT;
    END PROCESS t_prcs_N_25;
    -- N
    t_prcs_N_24: PROCESS
    BEGIN
        N(24) <= '0';
    WAIT;
    END PROCESS t_prcs_N_24;
    -- N
    t_prcs_N_23: PROCESS
    BEGIN
        N(23) <= '0';
    WAIT;
    END PROCESS t_prcs_N_23;
    -- N
    t_prcs_N_22: PROCESS
    BEGIN
        N(22) <= '0';
    WAIT;
    END PROCESS t_prcs_N_22;
    -- N
    t_prcs_N_21: PROCESS
    BEGIN
        N(21) <= '0';
    WAIT;
    END PROCESS t_prcs_N_21;
    -- N
    t_prcs_N_20: PROCESS
    BEGIN
        N(20) <= '0';
    WAIT;
    END PROCESS t_prcs_N_20;
    -- N
    t_prcs_N_19: PROCESS
    BEGIN
        N(19) <= '0';
    WAIT;
    END PROCESS t_prcs_N_19;
    -- N
    t_prcs_N_18: PROCESS
    BEGIN
        N(18) <= '0';
    WAIT;
    END PROCESS t_prcs_N_18;
    -- N
    t_prcs_N_17: PROCESS
    BEGIN
        N(17) <= '0';
    WAIT;
    END PROCESS t_prcs_N_17;
    -- N
    t_prcs_N_16: PROCESS
    BEGIN
        N(16) <= '0';
    WAIT;
    END PROCESS t_prcs_N_16;
    -- N
    t_prcs_N_15: PROCESS
    BEGIN
        N(15) <= '0';
    WAIT;
    END PROCESS t_prcs_N_15;
    -- N
    t_prcs_N_14: PROCESS
    BEGIN
        N(14) <= '0';
    WAIT;
    END PROCESS t_prcs_N_14;
    -- N
    t_prcs_N_13: PROCESS
    BEGIN
        N(13) <= '0';
    WAIT;
    END PROCESS t_prcs_N_13;
    -- N
    t_prcs_N_12: PROCESS
    BEGIN
        N(12) <= '0';
    WAIT;
    END PROCESS t_prcs_N_12;
    -- N
    t_prcs_N_11: PROCESS
    BEGIN
        N(11) <= '0';
    WAIT;
    END PROCESS t_prcs_N_11;
    -- N
    t_prcs_N_10: PROCESS
    BEGIN
        N(10) <= '0';
    WAIT;
    END PROCESS t_prcs_N_10;
    -- N
    t_prcs_N_9: PROCESS
    BEGIN
        N(9) <= '0';
    WAIT;
    END PROCESS t_prcs_N_9;
    -- N
    t_prcs_N_8: PROCESS
    BEGIN
        N(8) <= '0';
    WAIT;
    END PROCESS t_prcs_N_8;
    -- N
    t_prcs_N_7: PROCESS
    BEGIN
        N(7) <= '0';
    WAIT;
    END PROCESS t_prcs_N_7;
    -- N
    t_prcs_N_6: PROCESS
    BEGIN
        N(6) <= '0';
    WAIT;
    END PROCESS t_prcs_N_6;
    -- N
    t_prcs_N_5: PROCESS
    BEGIN
        N(5) <= '1';
    WAIT;
    END PROCESS t_prcs_N_5;
    -- N
    t_prcs_N_4: PROCESS
    BEGIN
        N(4) <= '1';
    WAIT;
    END PROCESS t_prcs_N_4;
    -- N
    t_prcs_N_3: PROCESS
    BEGIN
        N(3) <= '0';
    WAIT;
    END PROCESS t_prcs_N_3;
    -- N
    t_prcs_N_2: PROCESS
    BEGIN
        N(2) <= '1';
    WAIT;
    END PROCESS t_prcs_N_2;
    -- N
    t_prcs_N_1: PROCESS
    BEGIN
        N(1) <= '0';
    WAIT;
    END PROCESS t_prcs_N_1;
    -- N
    t_prcs_N_0: PROCESS
    BEGIN
        N(0) <= '0';
    WAIT;
    END PROCESS t_prcs_N_0;
    -- sync_in
    t_prcs_sync_in: PROCESS
    BEGIN
        sync_in <= '1';
        WAIT FOR 7000 ps;
        FOR i IN 1 TO 9
        LOOP
            sync_in <= '0';
            WAIT FOR 50000 ps;
            sync_in <= '1';
            WAIT FOR 50000 ps;
        END LOOP;
        sync_in <= '0';
        WAIT FOR 50000 ps;
        sync_in <= '1';
    WAIT;
    END PROCESS t_prcs_sync_in;
    tb_sample : test_project_vhd_sample_tst
    PORT MAP (
        N => N,
        sync_in => sync_in,
        sampler => sampler
    tb_out : test_project_vhd_check_tst
    PORT MAP (
        sync_out => sync_out,
        sampler => sampler
    END test_project_arch;
    That stuff at the beginning of the text file is defining a load of procedures that write different types out to a file. Any generated code tends to have a load of stuff that probably be hidden away in a package if you wrote it yourself.
    How did you convert the simulation file from a .wvf file to a testbench HDL file?
