17 years agoSimple Ethernet port.
I've been tasked with trying to get a simple ethernet port onto some of our specialty boards. For the most part they'd be used to send down control commands and read back simple status. Likely as not the physical connection would be a laptop ether-cable connected to the board but we might want to put them on the network during testing and debug so we don't want conflicts there. It'd be set up with its own IP Address and would respond to only those packets sent to that address. We purchased the Triple Speed Ethernet IP from Altera as wel as a newer Nios II dev brd. Now I've been going through ALL the Altera tutorials, (huge) documents and many other things as well and come to several conclusions.
The big one is that we don't need an OS and hence don't really need the Nios processor. Its all too big and particularly too complicated for our needs. The "simple socket server" example alone is not at all simple, I can't even figure out where to plug in our set IP Address into it. I've been through all the Altera examples and they require at least two engineers, FPGA designer and Embedded Systems Programmer, to perform simple manipulations. I'm alone, FPGA designer. What we do need is a simple hardware register set Protocol Stack design. We're willing to buy the IP for such but don't yet know where to find it. Does someone out there know? Looking for all feedback on this!:confused:
