17 years agoSimple Ethernet port.
I've been tasked with trying to get a simple ethernet port onto some of our specialty boards. For the most part they'd be used to send down control commands and read back simple status. Likely as not...
17 years agoWell there are certainly gateware only ethernet IP out there. For example, Altera and Xilinx both have Video over ethernet reference designs that don't require a processor. These obviously implement some limited UDP/IP functionality.
Would these help: 1 - A non-processor ethernet reference design from Altera: http://www.altera.com/support/refdesigns/ip/interface/ref-triple-speed-ethernet-data-path.html?gsa_pos=7&wt.oss_r=1&wt.oss=ethernet 2 - A non-processor video over IP reference design from Altera: http://www.altera.com/support/refdesigns/sys-sol/broadcast/ref-video.html FYI I obtained the above by simply doing a search on keyword "ethernet" on Altera's website. 3 - Video over IP reference design from Xilinx: http://www.xilinx.com/publications/prod_mktg/pn0010973.pdf 4 - Board reference design using ethernet from Xilinx (Uses PowerPC): http://www.xilinx.com/support/documentation/boards_and_kits/ug355.pdf 5 - Gigabit ethernet reference design from Xilinx (Uses PowerPC): http://www.xilinx.com/support/documentation/application_notes/xapp536.pdf?archived 6 - Another Xilinx app note using a 3rd party TCP/IP stack: http://www.xilinx.com/support/documentation/application_notes/xapp546.pdf?archived 7 - A university project VHDL TCP/IP stack: http://www.itee.uq.edu.au/~peters/xsvboard/index.html 8 - You might consider reading this. I think it does a good job of illustrating the complexity involved in doing a UDP/IP stack in an FPGA. TCP is only more difficult. http://www.design-reuse.com/articles/12012/an-analysis-of-fpga-based-udp-ip-stack-parallelism-for-embedded-ethernet-connectivity.html Jake
