YZhou98's avatar
YZhou98
4 months ago
Shift Register Inference on Intel FPGAs – LUT-based Implementation Similar to Xilinx SRL?
Hello, I am trying to understand how Quartus implements shift registers on Altera FPGAs, and whether there is an equivalent mechanism to the LUT-based shift registers available on Xilinx devices (e.g., SRL16/SRLC32 on UltraScale+).
On Xilinx UltraScale+, a multi-stage shift register (with no reset, single clock, simple shift pattern) is often inferred into an LUT configured as an SRL, which significantly reduces flip-flop usage and does not materially increase logic area.
Does Quartus infer any LUT-based shift-register structure (analogous to Xilinx SRL16/SRLC32), or are shift registers always implemented using either: flip-flops, or MLAB / M20K RAM structures?
  • Hi,
    LUT based RAM is named MLAB RAM  in Altera FPGA. It's available with 6 input LUT logic elements, e.g. Cyclone V, Cyclone 10 GX, Arria 10, Agilex. It can be used to implement small RAM but apparently no shift registers.
    Regards Frank
  • FvM's avatar
    FvM
    Regards Frank
    • KennyT_altera's avatar
      KennyT_altera
      Thank you for your clear explanation. I’d like to add a bit more detail regarding shift register inference on Altera FPGAs for clarity.
      You are correct—MLAB RAM (Memory Logic Array Block RAM) utilizes the 6-input LUTs in our newer device families (such as Cyclone V, Cyclone 10 GX, Arria 10, and Agilex), and serves as a distributed, small-capacity RAM resource. However, Quartus does not infer shift registers into MLABs in the same way Xilinx tools infer SRL16/SRLC32 primitives into LUTs.
      To summarize:
      • There is currently no direct equivalent to Xilinx’s SRL16/SRLC32 LUT-based shift register in Altera FPGAs.
      • Inference of shift registers in Quartus typically results in the use of flip-flops (FFs) within the logic array for shallow shift registers.
      • For deeper shift registers, Quartus may infer RAM-based implementations (using MLAB or M20K blocks), but these are not dedicated shift register resources and do not provide the same area and resource efficiency as Xilinx SRLs.
      • MLABs are well-suited for small RAM structures but are not natively configured as shift registers.
      We shall close the case.
      • YZhou98's avatar
        YZhou98
        Thank you for the detailed information. I noticed that the synthesis tool does not infer deeper shift registers into MLAB or M20K when the RTL process includes a reset. However, when the shift-register process does not include a reset, the tool does infer them into memory blocks. Is this behavior always expected?
