SDC syntax for declaring generated clocks
Below, I have pasted a module that i have created. Now, i want to declare the outputs of this module as clocks in the SDC constraint file. entity CLKCTRL is Port ( -- Clock CLK : in std_logic; -- Reset RESZ : in std_logic; -- System Bus Clock Divider Value BUSDIV : in std_logic_vector(1 downto 0); -- Output 0 Clock Divider Value O0DIV : in std_logic_vector(5 downto 0); -- Output 1 Clock Divider Value O1DIV : in std_logic_vector(5 downto 0); -- System Clock HCLK : out std_logic; -- Output 0 Clock O0CLK : out std_logic; -- Output 0 Inverted Clock O0CLKZ : out std_logic; -- Output 1 Clock O1CLK : out std_logic; -- Output 1 Inverted Clock O1CLKZ : out std_logic); end CLKCTRL; architecture Behavioral of CLKCTRL is -- System Clock Counter signal count_HCLK : std_logic_vector(1 downto 0); -- Output 0 Clock Counter signal count_O0CLK : std_logic_vector(5 downto 0); -- Output 1 Clock Counter signal count_O1CLK : std_logic_vector(5 downto 0); -- System Clock signal s_HCLK : std_logic; -- Output 0 Clock signal s_O0CLK : std_logic; -- Output 1 Clock signal s_O1CLK : std_logic; begin -- Based on the Value of BUSDIV -- System Clock is selected HCLK <= CLK when BUSDIV = "00" else s_HCLK; -- Based on the Value of O0DIV -- Output 0 Clock is selected O0CLK <= CLK when O0DIV = "000000" else s_O0CLK; -- Based on the Value of O0DIV -- Output 0 Inverted Clock is selected O0CLKZ <= not CLK when O0DIV = "000000" else not s_O0CLK; -- Based on the Value of O1DIV -- Output 1 Clock is selected O1CLK <= CLK when O1DIV = "000000" else s_O1CLK; -- Based on the Value of O1DIV -- Output 1 Inverted Clock is selected O1CLKZ <= not CLK when O1DIV = "000000" else not s_O1CLK; p_1: process(RESZ, CLK) begin if RESZ = '0' then count_HCLK <= (others => '0'); count_O0CLK <= (others => '0'); count_O1CLK <= (others => '0'); s_HCLK <= '0'; s_O0CLK <= '0'; s_O1CLK <= '0'; elsif CLK'event and CLK = '1' then -- Clock Generation for System Clock if count_HCLK >= conv_std_logic_vector(((conv_integer(BUSDIV)+1)/2),2) then if count_HCLK = BUSDIV then count_HCLK <= (others => '0'); else count_HCLK <= count_HCLK + 1; end if; s_HCLK <= '1'; else count_HCLK <= count_HCLK + 1; s_HCLK <= '0'; end if; -- Clock Generation for Output 0 Clock if count_O0CLK >= conv_std_logic_vector(((conv_integer(O0DIV)+1)/2),6) then if count_O0CLK = O0DIV then count_O0CLK <= (others => '0'); else count_O0CLK <= count_O0CLK + 1; end if; s_O0CLK <= '1'; else count_O0CLK <= count_O0CLK + 1; s_O0CLK <= '0'; end if; -- Clock Generation for Output 1 Clock if count_O1CLK >= conv_std_logic_Vector(((conv_integer(O1DIV)+1)/2),6) then if count_O1CLK = O1DIV then count_O1CLK <= (others => '0'); else count_O1CLK <= count_O1CLK + 1; end if; s_O1CLK <= '1'; else count_O1CLK <= count_O1CLK + 1; s_O1CLK <= '0'; end if; end if; end process p_1; end Behavioral; Regards, Anil.4 Replies
To do a divide by n, you create a signal that pulses every nth clock cycle (the signal is asserted for one full clock cycle out of every n clock cycles). That signal is used as the clock enable. The registers running at the slower speed with that enable are clocked by the full-speed clock signal; the enable gives the same effect as using a slower clock. You can use multicycle exceptions in TimeQuest to say that any path between clock-enabled registers is allowed n clock cycles for setup.
The Quartus II version 7.1 handbook shows how to describe the clock enable in HDL. Volume 1, Section II, Chapter 6, Example 6-31 has a VHDL example with a clock enable together with other control signals that you can omit if you don't need them. You need the nested "if" that describes the enable inside the "if" that detects the clock edge. Here's an example of a way to create the multicycle exceptions for a divide by n (set to divide by 4 in the example). This example uses get_fanouts to apply a single pair of setup and hold exceptions to all paths where the source and destination registers both use the same clock enable. The set_multicycle_path -from and -to fields each contain the full set of registers using the clock enable. TimeQuest will apply the multicycle exceptions to all the paths that actually exist between all possible pairings of these registers. When you use the clock enable resource in silicon, it is OK if the new data actually arrives at the destination sooner than the n clock cycles. The multicycle hold of n-1 tells TimeQuest that the old data does not have to be held during the clock cycles when the clock enable is deasserted.set all_enabled_registers ] set clock_enable_divide_by_n 4 set_multicycle_path -setup $clock_enable_divide_by_n -from $all_enabled_registers -to $all_enabled_registers set_multicycle_path -hold -from $all_enabled_registers -to $all_enabled_registers - Altera_Forum
Hi Brad,
Thanks for your reply. I have checked your post. But i have some problems. I cannot use PLL's. I just have a clock and i need to divide this directly. Now, how can i use a clock enable to get a divide by 1 or 2 or n clock , with approx 50% duty cycle. if this not possible. Let me know, how i can assign this divided clock to a global assignment. Because this doesn't exist on my top level entity for the FPGA. Regards, Anil. - Altera_Forum
Be careful about driving clocks with logic resources. Something like a clock divider is better done with a PLL if you have a PLL available or with a clock enable.
I have a post at http://www.alteraforum.com/forum/showthread.php?t=453&highlight=clock+enable with some considerations if you do use logic resources to do the clock division. - Altera_Forum
The following documents will help you set up time constrants in SDC for you design
http://www.altera.com/literature/hb/qts/ug_tq_tutorial.pdf - TimeQuest Analyzer Tutorial http://www.altera.com/literature/hb/qts/qts_qii53018.pdf - The Quartus II TimeQuest Timing Analyzer Cheers Rob Morley
