19 years agoSDC syntax for declaring generated clocks
Hello, Below, I have pasted a module that i have created. Now, i want to declare the outputs of this module as clocks in the SDC constraint file. entity CLKCTRL is Port ( -- Clo...
19 years agoThe following documents will help you set up time constrants in SDC for you design
http://www.altera.com/literature/hb/qts/ug_tq_tutorial.pdf - TimeQuest Analyzer Tutorial http://www.altera.com/literature/hb/qts/qts_qii53018.pdf - The Quartus II TimeQuest Timing Analyzer Cheers Rob Morley
