19 years agoSDC syntax for declaring generated clocks
Hello, Below, I have pasted a module that i have created. Now, i want to declare the outputs of this module as clocks in the SDC constraint file. entity CLKCTRL is Port ( -- Clo...
19 years agoHi Brad,
Thanks for your reply. I have checked your post. But i have some problems. I cannot use PLL's. I just have a clock and i need to divide this directly. Now, how can i use a clock enable to get a divide by 1 or 2 or n clock , with approx 50% duty cycle. if this not possible. Let me know, how i can assign this divided clock to a global assignment. Because this doesn't exist on my top level entity for the FPGA. Regards, Anil.
