The issue encountered when programming the POF file into MAX10
Hi Xingyunzhidi,
Are you using DK-DEV-AGI027-RA.? Please check the step 6 and 7 in this page: 3.5. Programming the Generated POF Image
JTAG ID code 0x020D10DD is the code of VTAP10.
After you connect the board to PC, open Programmer and then click "Auto Detect" to detect the current JTAG chain. As shown in the User Guide, normally you should would see VTAP10 in the chain instead of MAX 10 directly. So you need to follow the step 7: "Right click the VTAP10 device, Edit > Change Device, change it to MAX 10 > 10M50DAF256 ", click on MAX 10 device, then click "Change File" to add the factory image for MAX 10.
Xiaoyan
Hi Xiaoyan
Actually, I have followed your description and replaced the VTAP10 with MAX10 as shown in the diagram, but I am still encountering this issue. Could you please help me understand why this is happening?
