Jeffrey
3 days agoDK-DEV-AGI027RBES CXL Type-3 example remains in reset and is not detected by host
Hi, I have several Agilex 7 FPGA I-Series Development Kits with serial numbers 8100035 and 8020138. My goal is to run the boards as CXL Type-3 devices and verify that they can be enumerated by the h...
RongY_altera
Contributor
59 minutes agoHi Jeffrey,
Since you've already tried PCIe ED, I think you have no problem in generating the CXL project. Based on the CXL UG for Q25.1.1, these steps are described in below chapters:
3. Generating the Design Example
5. Compiling the Design Example
6. Running the Design Example in Hardware Setup
Pls notice you'll need to program the flash by following "6.3. Programming Agilex 7 I-Series Development Kit Image". Some details can also be found in this KDB.
Make sure the dev kit switch is set to boot from flash. After the flash is programmed, do a cold reboot of the sever.
Rong
