Cyclone V SoC 5CSXC6 Series GXB Utilization and Limitations
- 21 days ago
Hi Brian,
Thank you for the update.
Just to clarify, the legacy database I referred to is our internal database for legacy devices. Unfortunately, there is limited information available regarding this wrong data issue. Based on the available info, I believe it was originally initiated from a customer-reported case.
You are also correct that the placement rules are enforced within Quartus. Since these rules are built into the tool, they cannot be overridden through a TCL command.
I apologize for any inconvenience this may cause.
Hi Brian,
Please see my responses below:
Do you mean the CMU PLL is used by the RX channel in CH1 GXB?
[CP] To clarify, the CMU PLL utilizes the CDR PLL associated with the CH1 RX channel.
Is the wrong data issue caused by CMU PLL reuse? Would a custom TX operating at the same data rate as PCIe, or at a different data rate through the fPLL, also experience the same issue?
[CP] Based on information available in the legacy database, a custom TX operating at a different data rate than PCIe may also encounter the same wrong data issue.
Why can wrong data occur on a custom TX at CH1? What is the root cause?
[CP] I reviewed the available legacy database records but was unable to find any information related to the root cause. Therefore, I am unable to provide further comments on this specific behavior. As a best practice, we recommend following the Quartus placement guidelines to ensure proper design functionality.
Thank you.
OK.
For wrong data, you kept referring to legacy database, this is from internal FAE / staffs only?
Do wrong data reports from customers or internal smoke / sanity tests?
There is no way we can use with newer version no override no tcl command to bypass fitter rules on coexist?
Brian
- CheepinC_altera21 days ago
Hi Brian,
- BrianSune_Froum21 days ago
Contributor
I guess we had this more than enough on understanding the whold story.
I deeply appreciate the sharing and assisting on this ticket.
I will close and report as solution.
So I think 17.x is still worth to keep.
Thanks,Brian
