Cyclone III slave (PS) embedded memory errors
- 3 years ago
I think I've found the problem.
There is a trace connected to pin 76 on the master and pin 99 on the slave. Trace is pulled up to 3.3V via 2.2k
This **bleep** resistor was dead, and the trace was actually floating.
I didn't use this pins before, so I can't reveal the resistor is dead.
As I start to use it, all logic became a total mess. Something worked, something not. By elimination I found the culprit.
I can't explain how this trace connected with loading errors (when FPGA not even in user mode), but the fact is - replacing resistor solved all problems, ROMs working now (though I don't use them anymore).
Thanks to all, problem solved!
hi @Vic3Dexe ,
scope shot from oscilloscope is required so we know what happened in the trace DATA and DCLK. can you share that
thanks,
No problem as soon as someone share oscilloscope to me.
Where exactly you need traces? AS_DCLK/AS_DATA or SOUTH_DCLK/SOUTH_DATA (after buffers)?
I've cut traces and placed series resistors afters buffers (51R). Should I remove them before measurement?
- hareesh4 years ago
it's better to share at two points and one time measure with resistors and another time with out.
on data line and clk line are you using 51R resistor only ?
- Vic3Dexe4 years ago
Well, it will take some time to find oscilloscope.
Sorry, don't understand this question.
@Vic3Dexe wrote: I've cut traces and placed series resistors afters buffers (51R)
those resistors where are you connecting (data line or clk line or on both lines)
- if you see bellow attachment in schematic on clk and data lines using two different resistors in series.
Awaiting access to my friend's oscilloscope (it's in use for now). Don't know when it will be avail. Maybe this week, maybe next.
