Quartus and power domain
The temperature increase is happening before configuration.
This is abnormal elevated leakage in part of the die. Definitely not dynamic switching power.
Are you seeing this behavior at only 1 unit?
Next step:
1-can you try power up with slower ramp time? (within timing spec)
2- how many boards manufactured? All showing same behavior?
3- Is it possible to swap unit on the board with another one? - to see if the issue follows unit or follows board
4- Please send snap shot of the device top marking so I can analysia the production test history.
regards,
Farabi
I cant do conclusion with behavior description.
I need to check with production test history. We need the snapshot of the top marking at least 1 or 2 units.
This is critical for checking the rootcause.
regards,
Farabi
