Quartus and power domain
Can you response to my inquiry?
regards,
Farabi
- sbj2 months ago
Thank you Farabi for your reponse.
Please allow me some time to provide you a feedback :)
Cheers
- Farabi_Altera2 months ago
Noted. I will wait for your reply.
regards,
Farabi
- sbj2 months ago
Hi Farabi,
here are the answers I received to your questions
1-can you try power up with slower ramp time? (within timing spec)
It does not help.
2- how many boards manufactured? All showing same behavior?The behavior is reproducible on all three of our boards. I also observe very similar behavior on the Avnet evaluation board (with a slightly different package).
It appears to be temperature-dependent Vcore leakage.
3- Is it possible to swap unit on the board with another one?to see if the issue follows unit or follows board
The issue tracks temperature. Internal Agilex temperature sensors show a direct correlation between core rail current and die temperature.
4- Please send snapshot of the device top marking so I can analyse the production test history.no answer
Cheers
