Quartus 13.0 SP1 and Windows 11
Are the USB Blaster drivers compatible with Windows 11
- KennyT_altera
You are right for the above, since there are no further question, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- FvM
Thanks for mentioning.
We are talking solely about Quartus versions that have been released before any presently supported Windows or Linux OS and therefore can't be supported by recent OS.
Having said this, the answer to "You may refer to the release note for the OS support." is obvious.
Also Quartus 13.1, presently still available for download, doesn't support Windows beyond version 8.
Saying here, a Quartus version is "working" under Windows 10 or 11 simply means that it has produced functional FPGA code for a specific project. It may produce faults for other projects.
Frank - KennyT_altera
Please note that even if it is working, if there are bugs occurs, Altera usually will not support it since Quartus version is not supported in windows 11. You may refer to the release note for the OS support.
- FvM
if you have multiple Quartus versions on your computer, they'll use the latest installed JTAG server along with its driver stack. Therefore you don't necessarily need a Quartus 13 USB Blaster driver.
Quartus 13 isn't specified to work with Windows 11, but even older versions, e.g. Quartus 9 are apparently working well. https://community.intel.com/t5/Intel-Quartus-Prime-Software/Quartus-9-0-Support-amp-Installation-for-ACEX-1K-EP1K50TC144-3/m-p/1672107?search-action-id=348990923609&search-result-uid=1672107Regards
Frank
