15 years ago
Problem while loading a program with a time limited sof
Hello everyone,
I'm a french student from Polytech'Paris and I'm currently working on a project which has to use PCIe input and Ethernet output of the Stratix IV GX development board. I have to receive market data coming from the PCIe and send out some analytics as fast as possible with the Ethernet output.
I already managed to receive data and read them from the PCIe and my .sof .elf work perfectly on my computer running on linux.
For the output, I only use an Ethernet Generator, an Ethernet Monitor and a Triple Speed Ethernet provided by Altera.
Now that I have my time_limited_sof I load it on my board and try to run a Hello World but everytime I do I get the problem that is described here:
__________________________________________________________________________
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00. Pausing target processor: not responding. Resetting and trying again: FAILED. Leaving target processor paused
From what I've seen on this forum:
-I'm not closing the windows which says that I'm working with a time_limited sof (I also tried to load my time_limited_sof using nios2-configure-sof ...time_limited.sof)
-My clock is working fine (it's the same design as the one I used before)
-My unused pin are in tri-stated with weak pull-up
-My reset button is already connected to a toggle switch and I tried to upload my program with my switch in the position 0 and 1.
I'm working on a computer with RedHat Linux 5.5, Quartus 11.0 Full version (licensed) and NiosII IDE.
In order to load the .elf file, I use NiosII IDE (and I also tried to use nios2-download -g ...elf)
Has anyone ever resolved this problem before?
Thank you by advance.
    Thank you, I just found out that my design doesn't meet all timing requirements.
    My PLL are properly locked.
    I'm changing my timing requirement right now
    Did you specify timing constraints on your design and does it meet all timing requirements?
    If you use plls, are they properly locked?
