Problem using VHDL from a project lower in the heirarchy in an upper level
I created a very simple dual edge detector using D flip flops and a few logic gates. I created this using Megafunctions LPM_DFF, LPM_XOR, LPM_INV, and LPM_AND symbols. This project compiles and creates the VHDL and symbol without issue. When I try to use the symbol in a project, I am unable to compile the project and get the following error.
Error (10481): VHDL Use Clause error at lpm_dff_0.vhd(28): design library "work" does not contain primary unit "lpm_components" Error (10800): VHDL error at lpm_dff_0.vhd(28): selected name in use clause is not an expanded name Can help with why this rather straight forward application using only basic Quartus components would give this error? Are there some settings in generating the VHDL that are not correct? I have not changed anything and tried reinstalling. Any help would be greatly appreciated.14 Replies
--- Quote Start --- I am just manually setting the inputs and output in modelsim to do the simulation testing. --- Quote End --- Manually? How, using force statements, or using a top-level VHDL testbench. Its hard to help you if I have to guess. Just post your code, or some minimal code that demonstrates the error. The testbench that I referred you to probably has enough to get you started - try running it. Cheers, Dave - Altera_Forum
I have traced my problem to connectivity problems where it say some of the Q output of my FF's are connected dangling logic. I have try renaming, renumbering, splitting, and finally connect my buses only by signal names. I have attached my BDF file is someone can look at it and see what my problem is, I would be eternally grateful.
Dave I didn't see your previous reply before sending out my previous one. First, let me say thanks for your patience. I spent 3 years working with Quartus on multiple projects, but the last one was 5 years ago. Things have certainly changed a bit. To answer you question, only needed the equivalent of three clocks to test this circuit, so I just manually applied then using the same facility as force. Sorry if I was not clear enough in the past.
I opened up PLD_Proxy, and although you have a top-level BSF, and what looks like a generated top-level VHDL file, I do not see a testbench file, eg., PLD_Proxy_tb.vhd.
Without that file, you're not going to get very far with simulation. I'd recommend taking the time now to create a basic testbench containing a clock generator, and a process that drives valid signals onto the input ports. At that point you will be able to see whether the output ports are all driven to valid values. Then you can start to add test sequences. The testbench I posted should be enough to get you started. Cheers, Dave
