13 years agoProblem using VHDL from a project lower in the heirarchy in an upper level
I created a very simple dual edge detector using D flip flops and a few logic gates. I created this using Megafunctions LPM_DFF, LPM_XOR, LPM_INV, and LPM_AND symbols. This project compiles and cre...
13 years ago --- Quote Start --- I am just manually setting the inputs and output in modelsim to do the simulation testing. --- Quote End --- Manually? How, using force statements, or using a top-level VHDL testbench. Its hard to help you if I have to guess. Just post your code, or some minimal code that demonstrates the error. The testbench that I referred you to probably has enough to get you started - try running it. Cheers, Dave
