9 years ago
PLL is not working in Cylcone V GX (Using Integer PLL)
I have designed Customised board using Cyclone V GX FPGA.
I have fed 25MHz oscillator to non-dedicated clock pin in FPGA.
So i had incorporated ALCLKCTRL.
The design flow 25MHz -> altclkctrl ip -> altpll
In this case pll not locked and therefore no pll output
I have attached schematic file.
Please support.https://alteraforum.com/forum/attachment.php?attachmentid=13877&stc=1
    Yes - I looked at the bits of schematics you attached. The problem is, if you want to use a PLL, you're feeding your clock into the wrong pin. The PLL cannot be fed by that pin.
    Using an ALTCLKCTRL block won't help as it can't be fed by a clock going into the pin you've chosen. This IP block should be fed by the output of a PLL, not the other way round.
    You need to modify the board to either: a) feed the clock into a dedicated clock pin; or b) add a wire loop on your board between an unused I/O pin and a dedicated clock pin and feed your clock signal out of that I/O pin so that the clock is fed to a dedicated clock pin.
    Cheers,
    Alex
    If you must use a non-dedicated clock input pin, have you tried connecting to the PLL first instead of the clock control block? Why are you doing it in this order?
    hi alex,
    thanks for your reply.
    i can't figure out the thing why the pll is not locking.
    Have you refered those schematic files attached
    Is there anything wrong with schematics attached.
    Referring to the 'clock control block (altclkctrl) ip core user guide (https://www.altera.com/en_us/pdfs/literature/ug/ug_altclock.pdf)', only certain signals can drive the inclk port - those being:
    --- Quote Start ---
    Clock pins, clock outputs from the PLL, and core signals can drive the inclk[] port.
    --- Quote End ---
    'Ordinary' I/O pins cannot be connected to the ALTCLKCTRL inclk port. So, if your design ran through Quartus successfully, I suspect you've not got things connected up as you think - which may explain why the PLL isn't locking.
    Cheers,
    Alex
