DCack
4 months agoClarification on Arria 10 Design Security Features
We're working on securing the IP using design security features available in the Arria 10 FPGA. We went through the AN556 multiple times, but still some aspects are not clear to us.
- We've successfully configured the non-volatile key into the FPGA, but we did not set the tamper protection in the EKP file. Is it still possible to enable it on this device?
- Is the tamper protection set per key type (volatile/non-volatile)? Or is it effective for both volatile and non-volatile keys?
- Let's say that EKP and the encrypted bitstream leaked. Is it possible to extract the key from the EKP file to decrypt the bitstream?
- Is there a possibility to check from the FPGA fabric whether the non-volatile key was configured or not? I mean, e.g. is it possible to instantiate the Internal JTAG interface/WYSIWYG atom and execute the KEY_VERIFY instruction?
- If tamper protection is enabled, is it still possible to configure the FPGA with the SOF file?
- If JTAG secure mode is enabled, is it still possible to configure the FPGA using JTAG?
That's a lot of questions. Thanks in advance.
Damian
Hi Damian,
- Yes, it is still possible to enable it. Please refer to "Steps to Enable Tamper-Protection Bit Programming" of AN556
- It is effective for both volatile and non-volatile key. If you are using volatile key and tamper protection, please make sure that the VccBat is always connected. If the volatile key is loss due to the loss of VccBat voltage then the FPGA is no longer usable.
- Nope. There is no way to extract the key from the EKP file as it is encrypted key file
- Yes, it is possible to check. You will need to implement your own state machine to send the KEY_VERIFY instruction.
- No. Only encrypted bitstream is possible.
- No, unless you implement UNLOCK JTAG instruction though user logic.
John Tio- We've successfully configured the non-volatile key into the FPGA, but we did not set the tamper protection in the EKP file. Is it still possible to enable it on this device?
- JohnT_Altera
Hi Damian,
John Tio- DCack
That is very helpful, thank you so much.
