11 years agoPin constrain in sdc file
I have not make a FPGA design in Altera device for a while. Just have a question to double check, does Altera improve the functionality of sdc file that now we can put the pin constrains in the sdc file ? I remember previously we need put pin assignments in another file.
Thanks in advance.6 Replies
By "pin constrains" do you mean pin locations?
Timing constraints go in the sdc file. Pin location constraints go in the project's qsf file. Cheers, Alex - Altera_Forum
--- Quote Start --- By "pin constrains" do you mean pin locations? Timing constraints go in the sdc file. Pin location constraints go in the project's qsf file. Cheers, Alex --- Quote End --- Thanks. But may I put the pin locations in sdc file? - Altera_Forum
--- Quote Start --- Thanks. But may I put the pin locations in sdc file? --- Quote End --- But whyyyyyy? sdc is for timing, not for pins... Synopsis Design Constraints, try and see for yourself - Altera_Forum
--- Quote Start --- But whyyyyyy? sdc is for timing, not for pins... Synopsis Design Constraints, try and see for yourself --- Quote End --- I just saw a website mentioned this. http://www.altera.com/support/software/eda_maxplus2/synplty/intro/pin.html OK, I can write tcl in qsf to do the pin constrains. For one project, I can only have on qsf file, correct? Thanks. - Altera_Forum
One, and only one, qsf file per project.
--- Quote Start --- One, and only one, qsf file per project. Cheers, Alex --- Quote End --- Thanks a lot.
