9 years ago
PCIe Hard IP build error
i add two PCIe hard IP in my project(the FPGA device support two PCIe core),but Quartus show the error as follow, i am new to FPGA,could anybody help me solve the problem ? thanks very much!
Error (14566): Could not place 2 periphery component(s) due to conflicts with existing constraints (1 Hard IP(s), 1 Receiver channel(s))
Error (175020): Illegal constraint of Receiver channel that is part of Avalon-MM Cyclone V Hard IP for PCI Express altpcie_cv_hip_avmm_hwtcl to the region (0, 36) to (0, 38): no valid locations in region
Info (14596): Information about the failing component:
Info (175028): The Receiver channel name: pcie1_rx_p
Info (175015): The I/O pad pcie1_rx_p is constrained to the location PIN_R2 due to: User Location Constraints (PIN_R2)
Info (14709): The constrained I/O pad is contained within a pin, which is contained within this Receiver channel
    thanks for your help,i solve the problem now,it's all because of the "pin_perst" pin ,each Hard IP core should have a single "pin_perst" ,but in my original project,the two PCIe core share a pin_perst signal ,that's the problem.
    Section 1-5, P319 of the cyclone v handbook (https://www.altera.com/en_us/pdfs/literature/hb/cyclone-v/cyclone5_handbook.pdf).
    --- Quote Start ---
    The PCIe Hard IP blocks are located across Ch 1 and Ch 2 of bank GXB_L0, and Ch 1 and Ch 2 of bank GXB_L2.
    --- Quote End ---
    According to P31 of the cyclone v pin information (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/cyclone-v/5cgxfc7.pdf), Pin R2 of the F31 package corresponds to channel 0 of GXB_L2 and is therefore not supported. Pins N2 and K3 are supported as they correspond to channels 1 and 2.
    And what about all the other pins? If you have two Hard-IP cores, you will have at least 4 transceiver assignments, plus clock pin assignments, etc.
    the device is Cycone V 5cGXFC7D6F31C7ES,my project use two Avalon-MM Cyclone V hard IP for PCI-e,and all devices are native endpoint X1,the pin pcie1_rx_p is the RX channel in PCIe,i set it to PIN_R2 (GXB_L2) .
    We don't have crystal balls.
    What device are you using? What settings are you using for your hard-ip core? What pins are you constraining the transceivers and clocks to?
