onnecting the F-Tile Reference and System PLL Clock IP out_coreclk_#i port to an IOPLL FPGA IP
Hello Intel forums,
I'm trying to connect a out_coreclk from an F-tile Reference and System PLL Clock IP to an IOPLL. I understand that I cannot do this directly, so I'm following the workaround described here:
https://www.intel.com/content/www/us/en/support/programmable/articles/000098971.html
Here is my code:
clocko_blocko : block signal half_core : std_logic; component clk_ctrl is port ( inclk : in std_logic := 'X'; -- clk clock_div1x : out std_logic -- clk ); end component clk_ctrl; component pll is port ( refclk : in std_logic := 'X'; -- clk locked : out std_logic; -- export rst : in std_logic := 'X'; -- reset outclk_0 : out std_logic -- clk ); end component pll; signal half_core_iopll_ref : std_logic; signal source : std_logic; begin proc_halver : process(coreclk_feb) begin if rising_edge(coreclk_feb) then half_core <= not half_core; end if; end process proc_halver; clctrl : component clk_ctrl port map ( inclk => half_core, clock_div1x => half_core_iopll_ref ); ipll : component pll port map ( refclk => half_core_iopll_ref, locked => open, rst => rst, outclk_0 => clk_320 ); end block clocko_blocko;
Unfortunately. the pll never locks. Using a firmware module, I've measured the frequency of "coreclk_feb", "half_core", and "half_core_iopll_ref" and they all have correct values, but "clk_320" has a nonsensical value.
Are there particular settings needed for the Clock Control FPGA IP buffer and IOPLL FPGA IP that are not covered in the linked post? My IOPLL is set to double the input frequency to compensate for the division in the "proc_halver" process, is that a problem?
I've tried this in Quartus 23.4 and 24.3.1
Cheers,
Sam
- Ash_R_Altera
Could you verify if the port out_systempll_synthlock_i from F-tile system PLL IP gets asserted or not?
You could use this port ANDed with your system level reset to generate overall reset to the IOPLL.
Is the input clock to the system PLL always available and at the correct frequency?
I don't see any problem is generating a double frequency clock from the IOPLL.
- Ash_R_Altera
Please help me understand few things.
1) Are you checking the PLL status in HW or in simulation?
2) In the port map, the 'locked' signal is open. How are you checking the status of the PLL.
3) What is the status of rst input port to the PLL?
The frequency of the output clock from PLL is valid only after it gets locked. You should be measuring it only after lock.
- SDe_J
Thanks for your response. Here's my answer:
1. I am checking in HW
2. I use signaltap to monitor the port directly
3. 'rst' is low when I check the locked status.
Sam
