8 years agoNo logic elements although I have an output
Hello
Please guide me why I don't see any logic element for the current code : LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to define array of input ( package ) ENTITY test IS PORT ( clk: in std_logic; OutResult: out signed(9 downto 0)); end test; Architecture behave of test is Signal Im : Array2D:=(("0010000111","0001111110","0001001101","0000000000","0000000000"), ("0001001111","0010000100","0000101100","0000011011","0000000000"), ("0001011101","0010000100","0000100111","0000101001","0000000000"), ("0001011101","0010000100","0000100111","0000101001","0000000000"), ("0000000000","0000000000","0000000000","0000000000","0000000000")); signal Bufftemp:Array2D; signal Buffsig:signed(9 DOWNTO 0); begin Process (clk) variable i,j:integer range 0 to 7:=0; begin if (clk' event and clk='1') then for j in 0 to 1 loop for i in 0 to 1 loop Bufftemp(2*j,2*i+1)<= Im(2*j,2*i+1) - 5; end loop; end loop; end if; Buffsig<=Bufftemp(i,j); end process; OutResult<=Buffsig; end behave;26 Replies
--- Quote Start --- Initially, you may do better using the mega wizard to generate the ram, then you know for sure that a ram will be used. Infered ram has to match the correct behavioural template to be correctly inferred, otherwise logic will be inferred. Review this document for coding styles: https://people.ece.cornell.edu/land/courses/ece5760/de1_soc/hdl_style_qts_qii51007.pdf --- Quote End --- I didn't call memory using mega wizard before , so I will read the document carefully and try it. I am really thankful to you. You are really helping me. - Altera_Forum
--- Quote Start --- Initially, you may do better using the mega wizard to generate the ram, then you know for sure that a ram will be used. Infered ram has to match the correct behavioural template to be correctly inferred, otherwise logic will be inferred. Review this document for coding styles: https://people.ece.cornell.edu/land/courses/ece5760/de1_soc/hdl_style_qts_qii51007.pdf --- Quote End --- Dear Admin, I have created a memory ( but without wizard) and read it as follows PROCESS (clock) variable i:integer range -1 to 31:=-1; BEGIN IF rising_edge(clock) THEN i:=i+1; q1 <= ram1(i); -- output ( ram is mif file of 32 element, each of 3 bits) END IF; END PROCESS; ram1 is external file that I successfully read its data , each element read in one clock cycle. However , I am trying to get the first three elements after they read to apply a mathematical equation to them in next clock cycle. when I tried to create registers to carry the values , I unintentionally read three element at the same time so the memory transferred to logic elements. My question is , How can I store only three elements and add them and then I get another three to add while keep reading? I tried to postponed in this way but am not sure if its true BEGIN IF rising_edge(clock) THEN i:=i+1; reg1 <= ram1(i); reg2<=reg1; reg3<=reg2; q1<=reg3; - Altera_Forum
I highly suggest reading how memory works. You can only access 1 address per clock cycle. So if you really want to access 3 elements to add them, you will have to read them out over 3 clock cycles. You could pipeline the design to do the adds to minimise total latency.
I highly suggest using the megawizard ram, as this would become obvious. - Altera_Forum
--- Quote Start --- I highly suggest reading how memory works. You can only access 1 address per clock cycle. So if you really want to access 3 elements to add them, you will have to read them out over 3 clock cycles. You could pipeline the design to do the adds to minimise total latency. I highly suggest using the megawizard ram, as this would become obvious. --- Quote End --- When I create a wizard I don't see how to connect it with my vhdl code in Pedroni book or in the document you sent me. Also, I wonder if this way of reading in three clock cycles is efficient way IF rising_edge(clock) THEN i:=i+1; reg1 <= ram1(i); reg2<=reg1; reg3<=reg2; q1<=reg3; Or you suggest me better one? Thanks alot - Altera_Forum
Your code still suggests you think you're writing software. You are not. You need to understand how the hardware works before you should be writing the code - hence why I suggest drawing a diagram.
I suggest reading how the ram works from here: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram.pdf - Altera_Forum
--- Quote Start --- Your code still suggests you think you're writing software. You are not. You need to understand how the hardware works before you should be writing the code - hence why I suggest drawing a diagram. I suggest reading how the ram works from here: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram.pdf --- Quote End --- Ok. I will . Thank you.
