8 years agoNo logic elements although I have an output
Hello Please guide me why I don't see any logic element for the current code : LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to def...
8 years ago --- Quote Start --- Your code still suggests you think you're writing software. You are not. You need to understand how the hardware works before you should be writing the code - hence why I suggest drawing a diagram. I suggest reading how the ram works from here: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram.pdf --- Quote End --- Ok. I will . Thank you.
