8 years agoNo logic elements although I have an output
Hello Please guide me why I don't see any logic element for the current code : LIBRARY ieee; USE ieee.std_logic_1164.all; Use ieee.numeric_std.all; USE work.my_data_types.all; -- to def...
8 years ago --- Quote Start --- I highly suggest reading how memory works. You can only access 1 address per clock cycle. So if you really want to access 3 elements to add them, you will have to read them out over 3 clock cycles. You could pipeline the design to do the adds to minimise total latency. I highly suggest using the megawizard ram, as this would become obvious. --- Quote End --- When I create a wizard I don't see how to connect it with my vhdl code in Pedroni book or in the document you sent me. Also, I wonder if this way of reading in three clock cycles is efficient way IF rising_edge(clock) THEN i:=i+1; reg1 <= ram1(i); reg2<=reg1; reg3<=reg2; q1<=reg3; Or you suggest me better one? Thanks alot
