8 years ago
No logic elements although I have an output
Hello
Please guide me why I don't see any logic element for the current code :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
Use ieee.numeric_std.all;
USE work.my_data_types.all; -- to define array of input ( package )
ENTITY test IS
PORT (
clk: in std_logic;
OutResult: out signed(9 downto 0));
end test;
Architecture behave of test is
Signal Im : Array2D:=(("0010000111","0001111110","0001001101","0000000000","0000000000"),
("0001001111","0010000100","0000101100","0000011011","0000000000"),
("0001011101","0010000100","0000100111","0000101001","0000000000"),
("0000000000","0000000000","0000000000","0000000000","0000000000"));
signal Bufftemp:Array2D;
signal Buffsig:signed(9 DOWNTO 0);
begin
Process (clk)
variable i,j:integer range 0 to 7:=0;
begin
if (clk' event and clk='1') then
for j in 0 to 1 loop
for i in 0 to 1 loop
Bufftemp(2*j,2*i+1)<= Im(2*j,2*i+1) - 5;
end loop;
end loop;
end if;
Buffsig<=Bufftemp(i,j);
end process;
OutResult<=Buffsig;
end behave;
    --- Quote Start ---
    Initially, you may do better using the mega wizard to generate the ram, then you know for sure that a ram will be used. Infered ram has to match the correct behavioural template to be correctly inferred, otherwise logic will be inferred.
    Review this document for coding styles:
    https://people.ece.cornell.edu/land/courses/ece5760/de1_soc/hdl_style_qts_qii51007.pdf
    --- Quote End ---
    I didn't call memory using mega wizard before , so I will read the document carefully and try it. I am really thankful to you. You are really helping me.
    --- Quote Start ---
    --- Quote End ---
    Dear Admin,
    I have created a memory ( but without wizard) and read it as follows
    PROCESS (clock)
    variable i:integer range -1 to 31:=-1;
    BEGIN
    IF rising_edge(clock) THEN
    i:=i+1;
    q1 <= ram1(i); -- output ( ram is mif file of 32 element, each of 3 bits)
    END IF;
    END PROCESS;
    ram1 is external file that I successfully read its data , each element read in one clock cycle.
    However , I am trying to get the first three elements after they read to apply a mathematical equation to them in next clock cycle. when I tried to create registers to carry the values , I unintentionally read three element at the same time so the memory transferred to logic elements.
    My question is , How can I store only three elements and add them and then I get another three to add while keep reading? I tried to postponed in this way but am not sure if its true
    BEGIN
    i:=i+1;
    reg1 <= ram1(i);
    reg2<=reg1;
    reg3<=reg2;
    q1<=reg3;
    I highly suggest reading how memory works. You can only access 1 address per clock cycle. So if you really want to access 3 elements to add them, you will have to read them out over 3 clock cycles. You could pipeline the design to do the adds to minimise total latency.
    I highly suggest using the megawizard ram, as this would become obvious.
    --- Quote Start ---
    --- Quote End ---
    When I create a wizard I don't see how to connect it with my vhdl code in Pedroni book or in the document you sent me.
    Also, I wonder if this way of reading in three clock cycles is efficient way
    i:=i+1;
    reg1 <= ram1(i);
    reg2<=reg1;
    reg3<=reg2;
    q1<=reg3;
    Or you suggest me better one?
    Thanks alot
