19 years agoNIOS II and flash compatibility
Hi All,
Can I use any CFI Flash device with NIOSII? In this case, where does the SOPC builder know where to get the flash driver from? Appreciate all the help. -sanjay5 Replies
--- Quote Start --- When I add a CFI in the " .ptf " , I find I can select 8/16/32bits data width with the flash. Is there any 32bits data width flash on sale? Most of the flash data width is 8/16bits width, what does the 32bits mean? --Yang --- Quote End --- 32Bits is done with 2 16Bit devices or 4 8bits devices. This CFI component is available in the SOPC_BUILDER for years and has been widely used for many FLASH founder. If you raise any issue, please flag mysupport.altera.com. Maga - Altera_Forum
Is there any 32bits data width flash on sale? Most of the flash data width is 8/16bits width, what does the 32bits mean? --Yang - Altera_Forum
Mostly all CFI Compliant Flash memories should work.
the devices need to comply with either AMD's or Intels CFI spec.
--dalon - Altera_Forum
Isn't the point that if the flash is CFI-compliant it should, in theory, just work? You do need to specify the signal timings for your device. There is a list of devices verified as compatible in the NIOS II Flash Programmer User Guide.
Has anyone had trouble getting a particular CFI-compliant flash working?
