NIOS II and Cyclone III Remote Update
Have spent several days now searching and reading and think I am nearly there... but not quite. I am using the NIOS II core with SOPC builder. I use Quartus II for the FPGA image. This is a project I have inherited which kept the FPGA image in a ECPS64 and the software image in CFI. I have combined the two and keep them in the EPCS64. Works OK. I have been trying to get the remote update controller to work. I have put it into the core via SOPC and can read and write its registers via NIOS. I can also make it do a reconfig but it always seems to use the factory image. Has any one got a working example using the Cyclone III and NIOS II?
I use the following to read 2 of the registers... ParamValue = IORD( REMOTE_UPDATE_CYCLONEIII_0_BASE, 0x4); ParamValue = IORD( REMOTE_UPDATE_CYCLONEIII_0_BASE, 0x0); After power on both registers read 0. After reconfig command, register 0 = 1 and register 4 = 8 Any ideas please? Brain is starting to hurt!69 Replies
Probably being a bit stupid here but... how do I make the boot_loader........ciii.s file? Changeing it using a text editor is easy enough but then how do I assemble it? I'm not that familiar with the command shell and how to use it.
Here is the CIII bootloader source files attached and the .hex generation procedure.
Steps: - open Nios II command shell and go to bootloader project directory - change EPCS_SRC_ADDR in boot_loader.h with desired boot address for Nios application - build the custom bootloader, which generates a epcs_controller_boot_rom_A.hex file (simply type 'make') - replace the existing epcs_controller_boot_rom.hex file in Quartus project with the newly generated one (thus removing _A) - select Quartus Processing menu, then Update Memory Initialization file - select Quartus Processing menu, then Start -> Start Assembler - the generated sof file will boot from the specified address Remark: I copied and pasted from notes written a long ago for one of my designs, so I'm not 100% sure everything is right for you . This also answer to your first question: yes, the hex bootloader code is encapsulated into sof file Good luck! - Altera_Forum
Making progress, I think. It now doesn't run the second software image at all because I guess it cannot find it. I found another bootloader (I couldn't get the one above to make). This one has these lines in it...
//cal // ofset to where the code is loaded in the epcs device // these need to be updated. # define SOFTWARE_OFFSET 0x1c0000 # define EPCS_FLASH_CONTROLLER_0_BASE 0x2000 // offset to the beginning of the hardware for the epcs ( not the rom) # define EPCS_BASE_PLUS_400 (EPCS_FLASH_CONTROLLER_0_BASE+0x400) Embarrasingly not sure what to set them at. I was trying to put my second fpga image at 0x200000 and second code at 0x400000. I set the software offset to 0x400000. What do I do with the other 2. Any ideas please. So near, yet so far!! - Altera_Forum
What's the problem?
EPCS_FLASH_CONTROLLER_0_BASE must simply match the actual base address of epcs controller in your sopc system. - Altera_Forum
Still no luck. I am using the boot loader 'my_boot_loader_standalone.S'. I change the lines as shown below. SOPC says my EPCS base address is 0x801800. I put my software file at 0x400000 using the Quartus Programmer.
// ofset to where the code is loaded in the epcs device // these need to be updated. # define SOFTWARE_OFFSET 0x400000 # define EPCS_FLASH_CONTROLLER_0_BASE 0x801800 On power up my 1st FPGA and 1st software image run fine. When I reconfig, my 2nd FPGA image runs but no software seems to run. Any help much appreciated. - Altera_Forum
I don't know if it applies to your system, but on my designs I layout my EPCS flash locations as:
Address 0: Factory SOF Address (-after Factory SOF): Factory Software Address 0x500000: Application SOF Address (-after Application SOF): Application Software Where -after is done using the --after switch in my programming script (for the NIOS II command shell) Example below: sof2flash --input=fpga_factory.sof --output=fpga_factory.flash --epcs --verbose elf2flash --input=software_factory --output=software_factory.flash --epcs --after=fpga_factory.flash --verbose This is done since the bootloader normally points to the starting address of your .SOF (normally 0, my modified code points to 0x500000). From here it determines the size of your .SOF and seeks to the end to look for your software. I hope this helps. - Altera_Forum
I'd start doing what I would do to debug a bootloader....
Find some simple peripheral (like a LED) and see if I can make it work (eg flash). That gives you some confidence that you stand a chance of actually booting something. If you have a UART it is a bit easier - you can write single bytes to the fifo and follow the progress. - Altera_Forum
Thats what I am doing. My FPGA toggles a pin. My software toggles another pin. The toggle frequency is different depending on the image loaded. At power up the 1st image is loaded and this can be confirmed by the pin toggle frequencies. When I reconfig (via serial command) the 2nd FPGA image is loaded (pin toggle frequency changes) but the pin the software is toggling doesnt toggle anymore. So 2nd software image isnt running. It's something to do with the settings in the bootloader in the 2nd FPGA image.(1st FPGA image uses default bootloader).
Still not working, still confused. Ok. For the 'factory' image I create a combined sof and elf and convert/program it into the EPCS64 using the Quartus Prorammer. This works as it should. For the second sof I use modified boot loader code and then using Quartus Programmer I put it into the EPCS64 at address 0x0200000. The remote reconfig in the 'factory' image points to this address. The second elf is programmed in at address 0x0400000. Factory version still works fine. Send a reconfig command and 2nd sof is run ok but second elf isnt, no software running at all. If I build the 2nd sof with default boot loader it loads the 'factory' elf which then runs ok. So I end up with 2nd FPGA image running and 'factory' software.
I am using a bootloader called 'my_boot_loader_standalone.S' My SOPC reports my EPCS has a base address of 0x0801800. The bootloader needs # define SOFTWARE_OFFSET. Where is this offset from? I put in 0x0400000 which is where my elf starts in the EPCS. Is this correct? It also asks for# define EPCS_FLASH_CONTROLLER_0_BASE which I have set to 0x0801800. Again is this correct? Sorry to be stupid here but I seem to be going around in circles. - Altera_Forum
The meaning of SOFTWARE_OFFSET constant depends on your actual bootloader.
If this a 'true' offset probably the correct value would be 0x200000 rather than 0x400000 (i.e. the offset between fpga image and elf) But it could also refer to the free space offset from end of fpga sof image to start of elf, although this would be not recommended since this is not a well defined value. Other smart bootloaders (IIRC the default one, too), are able to automatically detect the end of sof image and start loading from there. Look into the bootlaoder code and find it out.
