13 years agoNIOS II and Cyclone III Remote Update
Have spent several days now searching and reading and think I am nearly there... but not quite. I am using the NIOS II core with SOPC builder. I use Quartus II for the FPGA image. This is a projec...
13 years agoHere is the CIII bootloader source files attached and the .hex generation procedure.
Steps: - open Nios II command shell and go to bootloader project directory - change EPCS_SRC_ADDR in boot_loader.h with desired boot address for Nios application - build the custom bootloader, which generates a epcs_controller_boot_rom_A.hex file (simply type 'make') - replace the existing epcs_controller_boot_rom.hex file in Quartus project with the newly generated one (thus removing _A) - select Quartus Processing menu, then Update Memory Initialization file - select Quartus Processing menu, then Start -> Start Assembler - the generated sof file will boot from the specified address Remark: I copied and pasted from notes written a long ago for one of my designs, so I'm not 100% sure everything is right for you . This also answer to your first question: yes, the hex bootloader code is encapsulated into sof file Good luck!
