13 years agoNIOS II and Cyclone III Remote Update
Have spent several days now searching and reading and think I am nearly there... but not quite. I am using the NIOS II core with SOPC builder. I use Quartus II for the FPGA image. This is a projec...
13 years agoStill not working, still confused. Ok. For the 'factory' image I create a combined sof and elf and convert/program it into the EPCS64 using the Quartus Prorammer. This works as it should. For the second sof I use modified boot loader code and then using Quartus Programmer I put it into the EPCS64 at address 0x0200000. The remote reconfig in the 'factory' image points to this address. The second elf is programmed in at address 0x0400000. Factory version still works fine. Send a reconfig command and 2nd sof is run ok but second elf isnt, no software running at all. If I build the 2nd sof with default boot loader it loads the 'factory' elf which then runs ok. So I end up with 2nd FPGA image running and 'factory' software.
I am using a bootloader called 'my_boot_loader_standalone.S' My SOPC reports my EPCS has a base address of 0x0801800. The bootloader needs # define SOFTWARE_OFFSET. Where is this offset from? I put in 0x0400000 which is where my elf starts in the EPCS. Is this correct? It also asks for# define EPCS_FLASH_CONTROLLER_0_BASE which I have set to 0x0801800. Again is this correct? Sorry to be stupid here but I seem to be going around in circles.
