15 years ago
multiple driver error during simulation
Hi
I am doing a project and am stuck in the synthesis part in Quartus.
The code was successfully compiled using icarus verilog software.But while compiling the code in Quartus , I get some error messages.
The code is as follows with its description:
Whenever positive edge of switch occurs , I need to take the incoming 8 bits (serial inputs on a single pin) and after that I
have to discard all the bits, until the next posedge of switch. These bits are coming from a parallel in serial out register.
These bits are stored in a reg called c and i is an integer which keeps the count.
module test(si,po,clk,switch,flag);
input si,clk,switch;
output reg [7:0] po;
reg [7:0] c,d;
output reg flag;
reg count;
//reg flag;
integer j,i;
initial i=0;
initial flag=0;
initial count=0;
always@(posedge clk)
begin
if (flag==1)
begin
c[i]=si;
i=i+1;
if(i==8)
begin
//count<=1;
//po<=c;
po<=(c[7:4]*10)+c[3:0];
i=0;
flag<=0;
end
end
end
always@(posedge switch)
begin
flag<=1;
end
endmodule
The error messges are as follows:
Error: Can't elaborate top-level user hierarchy
Error (10029): Constant driver at test.v(16)
Error (10028): Can't resolve multiple constant drivers for net "flag" at test.v(38)
Could anyone help in rectifying the mistake?
    if your 8 bits are serial then they can't all come at rising edge of switch but one after the other as per input clock edge otherwise you need to clearify this point. I know RS232 uses no clock. Instead you run a counter to read bits by guess in effect... is that your case as well? is your clock as fast as serial bit stream?
    --- Quote Start ---
    I am not sure if switch will rise once only or many times.
    ...etc.
    --- Quote End ---
    Yes switch is allowed transitions
    "if switch = '1' and switch_d = '0' then" If I am not wrong this is detecting the positive edge
    So my count needs to be increased only when there is a positive edge and inputs(serial 8 bits) need to be stored in a reg.
    Moreover, me being familiar with Verilog, not VHDL, the syntax
    output(count) <= input;
    is troubling me
    You are right, I am still playing with this code for demo only as I am not aware of your inputs behaviour.
    remember you can only detect switch edge one clock period after it rises.
    you can run count 0~7 instead of 0 ~ 8 then it will set back to 0 ready waiting for switch to go up again.
    count <= 1;
    else
    count <= count + 1; -- 0~7 free running
    end if;
    ...etc.
    --- Quote Start ---
    (vhdl clocked process)
    --detect edge of switch
    switch_d <= switch;
       count <= 1;
    elsif count < 8 then
       count <= count + 1;
    end if;
    if count < 8 then
    end if;
    if count = 7 then
        valid <= '1';
    else
        valid <= '0';
    end if;
    --- Quote End ---
    As per the specifications the first 8 inputs are to be taken at the positive edge of switch.
    So why do you set count =1 at +ve edge and increase it by 1 when there's no posedge of switch?
    2)
    if count < 8 then output(count) <= input; end if;
    what is this used for?
    I just corrected the output assignment.
    Yes I detect switch rising level, the count is set to 1 due to one clock latency.
    for safer design you may put this for edge detection:
    if switch = '1' and switch_d = '0' then instead
    Hi Kaz
    I have some doubts on your expalaination as follows:
    switch_d <= switch; if switch /= switch_d then count <= 1; else count <= count + 1; end if;
    1)by this are you detecting positive edge of switch
    2)
    output <= input(count);
    what does this do?
    Your flag is driven in two processes. the second process sets it permanently to high...
    You must have a clock input as fast as serial stream (at least) then you run a counter(integer 0 ~ 8) set at zero at MSB or LSB location then increment to 8 and reset zero.
    switch_d <= switch;
       count <= 1;
       count <= count + 1;
    end if;
    if count < 8 then
    end if;
    if count = 7 then
        valid <= '1';
    else
        valid <= '0';
    end if;
