14 years agomulti case_sentence cause delay
Hi
when I write the verilog code,like:
case(first_c)
3'd7:case(second_c)
3'd7:express..
3'd6:......
3'd5:......
3'd4:
3'd3:
3'd2:
3'd1:
3'd0:
endcase
3'd6:......
3'd5:......
3'd4:......
3'd3:......
3'd2:......
3'd1:......
3'd0:......
endcase
I find the circuit delay a lot. Is that the problem of case inside case ??? Thanks!!4 Replies
What is delay a lot? Some ns? Multiple clock cycles?
The construct involves combinational logic according to the complexity of the case decoder and the expression itself. But it's unlikely to accumulate more than a few ns logic delay. --- Quote Start --- Is that the problem of case inside case ??? --- Quote End --- Not particularly. - Altera_Forum
But when I revise the code,like:
case({first_c,second_c}) {3'd7,3'd7}:expression.. {3'd7,3'd6}:expression.. endcase the Fmax turns out increased almost10M!that's why I guess the "case inside case"cause to decrease the fmax.(my clk is 250M) - Altera_Forum
250 MHz is fast enough that one or two LEs in a logic chain play a role. This answers my first question. The difference between 250 and 260 MHz isn't more than 0.15 ns delay, rather a result of different routing than a full LE delay step.
My primary assumption is, that equivalent logic synthesizes to the same gate level netlist. Thus I also assume, that your two variants aren't logically equivalent, but it's most likely not a matter of nested case constructs. If the constructs are equivalent can't be seen from one or two lines of code. - Altera_Forum
thanks,FvM!
as a matter of fact,the 2 variants are equivalent,both 3 bits. I trial and error some times,the outcome is the same. code as follows the fmax is low.(clk=250M)
codes as follows increases the fmaxcase(first_c) 3'd7:case(second_c) 3'd7:express.. 3'd6:...... 3'd5:...... 3'd4: 3'd3: 3'd2: 3'd1: 3'd0: endcase 3'd6:case(second_c) 3'd7:express.. 3'd6:...... 3'd5:...... 3'd4: 3'd3: 3'd2: 3'd1: 3'd0: endcase 3'd5:case(second_c) 3'd7:express.. 3'd6:...... 3'd5:...... 3'd4: 3'd3: 3'd2: 3'd1: 3'd0: endcase 3'd4:case(second_c) 3'd7:express.. 3'd6:...... 3'd5:...... 3'd4: 3'd3: 3'd2: 3'd1: 3'd0: endcase 3'd3:case(second_c) 3'd7:express.. 3'd6:...... 3'd5:...... 3'd4: 3'd3: 3'd2: 3'd1: 3'd0: endcase 3'd2:case(second_c) 3'd7:express.. 3'd6:...... 3'd5:...... 3'd4: 3'd3: 3'd2: 3'd1: 3'd0: endcase 3'd1:case(second_c) 3'd7:express.. 3'd6:...... 3'd5:...... 3'd4: 3'd3: 3'd2: 3'd1: 3'd0: endcase 3'd0:case(second_c) 3'd7:express.. 3'd6:...... 3'd5:...... 3'd4: 3'd3: 3'd2: 3'd1: 3'd0: endcase endcase
the other correlative logic is the same.case({first_c,second_c}) {3'd7,3'd7}:expression.. {3'd7,3'd6}:expression.. ....... endcase
