16 years agoModelsim can not find "altsyncram"
Dear all, I am using Modelsim for simulation,
Modelsim says" Instantiation of 'altsyncram' failed, the design unit was not found", even though 'altsyncram' is in "Altera_mf" library, listed on the "library Panel". What should I do? Thank you very much! Other errors: "Instantiation of 'oper_selector' failed, the design unit was not found", there is a .ocp file in altmemphy-library, what does it do? should it be included in Modelsim?7 Replies
- migry_tech
Many thanks for the explanation listed as the 4 steps above. I am new to Modelsim-Altera and this solved the problem. I am now simulating my memory successfully, however I got caught out because I registered both the address and q without realising. Simulation and google(!) helped me find the bug.
--migry
--- Quote Start --- Could you tell me how to include? how to check? --- Quote End --- --- Quote Start --- I also met this problem. Have you fixed it? and How do you solve this problem? --- Quote End --- To resolve this problem you need to specify the right libraries when you are trying to simulate in ModelSim. The breif steps are 1. Compile the testbench code <testbench.v> , it gets included in your 'work' library. 2. Select 'Simulate' -> 'Start Simulation' from the menu. 3. Click on the 'Libraries' tab in the new popup window and press 'Add' to include the 'altera_mf_ver' library (if you are working with Verilog) to the 'Search Libraries First (-Lf)' 4. Finally, select your testbench from the 'Design' tab. The design should simulate now. I have included some screenshots for assistance. - Altera_Forum
I am using modelsim in a Ubuntu 10.04 LTS Lucid Lynx. Also i am compiling verilog files (and simulating them) in command line. I fixed it using the following command (after all necessary compilations): vsim -c -t 1ns -quiet -L $(MEGAFUNCTIONS) work.RomTests -do "run 1000000 1ns; quit" where MEGAFUNCTIONS should be your path to "altera_mf", which includes all megafunctions from altera: [installation path]/altera10.0/modelsim_ae/altera/verilog/altera_mf - Altera_Forum
--- Quote Start --- Dear all, I am using Modelsim for simulation, Modelsim says" Instantiation of 'altsyncram' failed, the design unit was not found", even though 'altsyncram' is in "Altera_mf" library, listed on the "library Panel". What should I do? Thank you very much! Other errors: "Instantiation of 'oper_selector' failed, the design unit was not found", there is a .ocp file in altmemphy-library, what does it do? should it be included in Modelsim? --- Quote End --- Hello binpersonal, I also met this problem. Have you fixed it? and How do you solve this problem? thanks! - Altera_Forum
# get a proper makefile
exec vmake work > Makefile # Run it to compile what needs to be compiled make # Start simulation vsim -L altera_mf_ver -L lpm_ver -L cycloneiii_ver -L cycloneii_ver work.dut_tb After those you can simply do: make; restart -f; run -all - Altera_Forum
Thank you very much! --- Quote Start --- Hi, did you include the library in your simulation ? Seeing the library in the library panel does not mean that they are included. Kind regards GPK --- Quote End --- - Altera_Forum
--- Quote Start --- Dear all, I am using Modelsim for simulation, Modelsim says" Instantiation of 'altsyncram' failed, the design unit was not found", even though 'altsyncram' is in "Altera_mf" library, listed on the "library Panel". What should I do? Thank you very much! Other errors: "Instantiation of 'oper_selector' failed, the design unit was not found", there is a .ocp file in altmemphy-library, what does it do? should it be included in Modelsim? --- Quote End --- Hi, did you include the library in your simulation ? Seeing the library in the library panel does not mean that they are included. Kind regards GPK
