16 years agoModelsim can not find "altsyncram"
Dear all, I am using Modelsim for simulation, Modelsim says" Instantiation of 'altsyncram' failed, the design unit was not found", even though 'altsyncram' is in "Altera_mf" library, listed on ...
15 years agoI also met this problem.
I am using modelsim in a Ubuntu 10.04 LTS Lucid Lynx. Also i am compiling verilog files (and simulating them) in command line. I fixed it using the following command (after all necessary compilations): vsim -c -t 1ns -quiet -L $(MEGAFUNCTIONS) work.RomTests -do "run 1000000 1ns; quit" where MEGAFUNCTIONS should be your path to "altera_mf", which includes all megafunctions from altera: [installation path]/altera10.0/modelsim_ae/altera/verilog/altera_mf
