16 years agoModelsim can not find "altsyncram"
Dear all, I am using Modelsim for simulation, Modelsim says" Instantiation of 'altsyncram' failed, the design unit was not found", even though 'altsyncram' is in "Altera_mf" library, listed on ...
15 years ago --- Quote Start --- Dear all, I am using Modelsim for simulation, Modelsim says" Instantiation of 'altsyncram' failed, the design unit was not found", even though 'altsyncram' is in "Altera_mf" library, listed on the "library Panel". What should I do? Thank you very much! Other errors: "Instantiation of 'oper_selector' failed, the design unit was not found", there is a .ocp file in altmemphy-library, what does it do? should it be included in Modelsim? --- Quote End --- Hello binpersonal, I also met this problem. Have you fixed it? and How do you solve this problem? thanks!
