16 years agoModelsim can not find "altsyncram"
Dear all, I am using Modelsim for simulation, Modelsim says" Instantiation of 'altsyncram' failed, the design unit was not found", even though 'altsyncram' is in "Altera_mf" library, listed on ...
16 years ago --- Quote Start --- Dear all, I am using Modelsim for simulation, Modelsim says" Instantiation of 'altsyncram' failed, the design unit was not found", even though 'altsyncram' is in "Altera_mf" library, listed on the "library Panel". What should I do? Thank you very much! Other errors: "Instantiation of 'oper_selector' failed, the design unit was not found", there is a .ocp file in altmemphy-library, what does it do? should it be included in Modelsim? --- Quote End --- Hi, did you include the library in your simulation ? Seeing the library in the library panel does not mean that they are included. Kind regards GPK
