sean793's avatar
sean793
6 months ago
MAX10 True LVDS 1.8V Input Characteristics Before and After Configuration
I have a design in which I would like to drive LVDS clock and data from an FPGA part from another manufacturer with a specified supply voltage of 1.5V.  This LVDS signal will then be received by an Altera MAX10 device using the true LVDS clock and data inputs.  Since the Altera part LVDS inputs are biased at 1.8V, is there any chance that the 1.8V input bias could show up or otherwise be observed at the driving device's output pins before, during, or after the MAX10 configuration?
  • Hi,
    in unconfigured state, input pins are pulled towards VCCIO through weak pull-up. Current is however low and shouldn't cause problems.
    Regards Frank
    • FvM's avatar
      FvM
      Hi Aqid,
      thanks for correcting my previous statement. Other than most Altera FPGA, e.g. Cyclone 10 LP, MAX 10 has IO weak pull-up disabled during first configuration phase. They are turned on in second configuration phase by default, but can stay disabled with respective configuration bit option (ICB settings in programming file generation tool).
      Frank
  • FvM's avatar
    FvM
    Regards Frank
