FrankK's avatar
FrankK
9 months ago
MAX10 nCONFIG pin slew rate requirement
is there any requirement for nCONFIG pin of MAX10 family with regards to signal transition time (signal slew rate)? Unfortunately MAX10 data sheet does not include any parameter for the same. It also does not specify, if the nCONFIG includes a Schnitt-Trigger feature which makes any slew rate demand redudant.
Best regards
Frank
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hi FrankK,
    To answer your question, Altera does not publish a slew‑rate spec for nCONFIG in the MAX 10 datasheet.  Refer MAX 10 FPGA Device Datasheet
    In practice, use a clean, monotonic nCONFIG edge and keep noise away from the threshold region. The Schmitt buffer helps, but clean edges are still best. MAX 10 FPGA Signal Integrity Design Guidelines
    Fakhrul
    • FrankK's avatar
      FrankK
      Dear Fakhrul,
      thanks a lot for your comprehensive answer.
      Best regards
      Frank
        FakhrulA_altera
        Hi FrankK,
        I'm glad that your issue is resolved. I will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
        Altera Technical Support
