MAX10 nCONFIG pin slew rate requirement
- 8 months ago
Hi FrankK,
To answer your question, Altera does not publish a slew‑rate spec for nCONFIG in the MAX 10 datasheet. Refer MAX 10 FPGA Device Datasheet
- During configuration, MAX 10 uses Schmitt‑trigger input buffers by default, so slow or noisy edges are tolerated. MAX 10 FPGA Signal Integrity Design Guidelines
- Schmitt input hysteresis is about 180 mV at 3.3 V, 150 mV at 2.5 V, 120 mV at 1.8 V, 110 mV at 1.5 V. Check here https://docs.altera.com/r/docs/683794/current/max-10-fpga-device-datasheet/hysteresis-specifications-for-schmitt-trigger-input
- To force reconfiguration, keep nCONFIG low at least 2 µs. https://community.altera.com/kb/knowledge-base/what-are-the-minimum-nconfig-low-pulse-width-and-the-maximum-nstatus-low-pulse-w/347246
- Connect nCONFIG high on power‑up, typically with a 10 kΩ pull‑up to VCCIO. Refer MAX 10 FPGA Device Family Pin Connection Guidelines
- Holding nCONFIG low to delay configuration does not relax the POR ramp‑time requirements. Try refer Possibility to avoid configuration power requirements for single-supply MAX10 by using nconfig
In practice, use a clean, monotonic nCONFIG edge and keep noise away from the threshold region. The Schmitt buffer helps, but clean edges are still best. MAX 10 FPGA Signal Integrity Design Guidelines
Fakhrul
Dear Fakhrul,
thanks a lot for your comprehensive answer.
Best regards
Frank
Hi FrankK,
I'm glad that your issue is resolved. I will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
Altera Technical Support
