MAX V - UFM IP core signals remain undefined when I try to simulate using a test bench
I have implemented a system where I store a 3 bit value to the UFM in my CPLD using a 'SET' signal, and read that value from the UFM using a 'GET' signal.
The system is running on the board partly (Enough to know the UFM is storing data and responding to read signal - using LEDs), but when I simulate using a testbench on modelsim - all the signals going into UFM and coming out is undefined. All the other signals are working fine.
Using MAX V CPLD
- Quartus Prime
- Modelsim
Do I need to include any UFM IP core library to my TB file? If so, please let me know how to do that?
Warnings:
- ** Warning: (vsim-3473) Component instance "ufm_parallel_0 : UFM_Config_ufm_parallel_0" is not bound.
- ** Warning: (vsim-8684) No drivers exist on out port /ufm_tb/UUT/ufm_inst/data_valid, and its initial value is not used.
- ** Warning: (vsim-8684) No drivers exist on out port /ufm_tb/UUT/ufm_inst/dataout, and its initial value is not used
- ** Warning: (vsim-8684) No drivers exist on out port /ufm_tb/UUT/ufm_inst/nbusy, and its initial value is not used.
It would be a great help.
VR_S
- IntelSupport
Contributor
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
- IntelSupport
Contributor
May I know if there is any update?
- IntelSupport
Contributor
Hi Raj,
There is few debug steps from the link below related to your issue. Can you verify all those suggestion and let me know.
- VR_S
To fix the bound issue:
How do I add the source file of component to the simulation test bench?
