16 years agoMax II CPLD design failing at low temperatures
I have a design that uses an industrial temperature Max II (EPM2210GF256I5). The design is very simple. It does some serial pass-through at 115,200 baud and some at a higher rate (16 x 64kHz). The master clock is just under 20MHz. If I put the board in an environmental chamber, it works fine at high temperatures, but on some devices the design begins to fail at around -10C. If I put an older version of the design in the same device, it works find down to -20C.
Does anyone know of any relevant application notes or have any suggestions on what to look into? Many thanks, -Michael2 Replies
Michael,
my bet would be that you're generating slower clocks from your 20MHz clock and that you're experiencing the effect of hold time time violations due to clock skew. First, I suggest you use TimeQuest with multi-corner analysis enabled, which should report that your design will fail for the fast timming model. Second, the following topic has a good explanation of the issues that arise with ripple clocks and alternative solutions http://alteraforums.com/forum/showthread.php?t=2388 - Altera_Forum
typical behaviour if your design is not FULLY synchronous :D Hope this help.
