14 years ago
mapping a port to several signals
Hi all!
I have got an issue, I don't really know if it's a bug from ModelSi or an error from my code.
Maybe soeone will be able to tell me...
A/° I am using:
--- Quote Start ---
ModelSim DE 6.6a
Revision: 2010.03
Date: Mar 19 2010
--- Quote End ---
B/° This code works:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity test is
end entity test;
architecture behavioural of test is
    component foo
    port
        s : out std_logic_vector(31 downto 0)
    end component foo;
    constant K : natural range 1 to 31 := 15;
    signal msb : std_logic_vector(31 downto K);
    signal lsb : std_logic_vector((K - 1) downto 0);
begin
    foo_inst : foo
    port map
        s(31 downto K)      => msb,
        s((K - 1) downto 0) => lsb
end architecture behavioural;
--- Quote Start ---
ModelSim> vcom -reportprogress 300 -work work /home/reinauld/Bureau/test.vhd
# Model Technology ModelSim DE vcom 6.6a Compiler 2010.03 Mar 19 2010
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Loading package numeric_std
# -- Compiling entity test
# -- Compiling architecture behavioural of test
ModelSim>
--- Quote End ---
C/° I tried to replace the constant K with e generic that I can set when starting the simulation, but it does not work
library ieee;
entity test is
    generic
end entity test;
    component foo
    port
    end component foo;
begin
    foo_inst : foo
    port map
--- Quote Start ---
# ** Error: /home/reinauld/Bureau/test.vhd(29): (vcom-1024) Individually associated formal "s" must be identified with a locally static name.
# ** Error: /home/reinauld/Bureau/test.vhd(30): (vcom-1024) Individually associated formal "s" must be identified with a locally static name.
# ** Error: /home/reinauld/Bureau/test.vhd(30): (vcom-1048) Non-locally static choice (association# 2, choice# 1) is allowed only if it is the only choice of the only association.
# ** Error: /home/reinauld/Bureau/test.vhd(33): VHDL Compiler exiting
# /opt/modelsim_de/modelsim_dlx/linuxpe/vcom failed.
ModelSim>
--- Quote End ---
Can anyone comment this? Maybe suggest another way to achieve what I try to do?
The point is to map output of a signal driver (that reads stimuli from a file) to several stimuli signals.
Julien
    Still, ModelSim is not consistent
    Slices with indexes that are not static:
    - are not allowed in port mapping
    - BUT are allowed in continuous affectations (in this case, if slices are wrong, the code compiles but the simulation crashes with an error message during load)
    The following examples illustrate this: they are perfectly identical from a functional point of view, but one compiles and the other does not.
    library ieee;
    entity test is
        generic
    end entity test;
        component foo
        port
        end component foo;
    begin
        foo_inst : foo
        port map
    --- Quote Start ---
    ModelSim>
    --- Quote End ---
    library ieee;
    entity test is
        generic
    end entity test;
        component foo
        port
        end component foo;
        signal sig : std_logic_vector(31 downto 0);
    begin
        foo_inst : foo
        port map
            s => sig
        msb <= sig(31 downto K);
        lsb <= sig((K - 1) downto 0);
    --- Quote Start ---
    ModelSim>
    --- Quote End ---
    Is there a reason?
    @kaz
    The code I proposed is for illustration only, it has no purpose.
    However you can imagine a testbench that generates stimuli from a file, instanciate a DUT, and checks outputs of the DUT in a process, reporting errors whenever they occur.
    This testbench would be an entity with no port, but with a generic for the stimuli file name for instance (in order to be able to run various scenarios without recompiling the testbench each time) --> just as in my example code.
    Also, it would instanciate a module as stimuli driver. This module would read the stimuli file and drive an 'out' signal accordingly. So basically this module would have only an 'out' port --> just as in my example code.
    (In that case, the driver would have the same generic as the testbench, and the generic would be propagated from the bench to the driver. But since this has nothing to do with my concern, so it was not necessary to my example code)
    --- Quote Start ---
    Is there a reason?
    --- Quote End ---
    yes. It will be part of the VHDL LRM that port maps have to be static but signal assignments dont need to be.
    Because rules are rules!! Dont question the LRM. ;)
    from the '93 LRM, section 1.1.1.2 Ports, line 94:
    "The actual, if a port or signal, must be denoted by a static name. The actual, if an expression, must be a globally static expression"
