Vigneswaran
4 months agoLVDS support on Agilex 7
HI, Im working on INTEL AGILEX 7 F-SERIES X2 F-TILE FPGA. Please clear my doubt In True differential signalling of LVDS , it is mentioned as differential signal with common mode voltage of 1.4 y...
FvM
4 months agoHi Vigneswaran,
you are right, DS90LV804 driver is at risk to exceed Agilex 7 absolute ratings due to larger Vocm tolerances. It should be also considered that on-chip rd termination is disabled in unconfigured FPGA state, resulting in even higher initial Vid. To keep on the safe side, I would either use a driver chip with tighter Vocm tolerance, add resistors that pull down common mode level or implement voltage dividers that shift signal level towards ground.
Frank
