sbj
2 months agoLVDS Compatibility with GTS Refclk (CML / HCSL)
We are evaluating a use case where an LVDS clock source drives a GTS transceiver reference clock input, which is typically configured for CML or HCSL standards. Is this usage supported, particula...
sbj
2 months agoHi,
is there a way to find out what pin configurations and electrical considerations (e.g., termination, biasing) are required to ensure proper operation?
Just some general documentation to have a better overview of what is inside the fpga and what needs to be added externally, would be very helpful.
Ash_R_Altera
2 months agoHi,
Please refer to the diagram in the following link showing the receiver buffer of Agilex 5 GTS. It shows Con-chip which is inside the FPGA and also Con-board, which user is supposed to put on the board.
As mentioned earlier, you may use the development kit as a reference. We recommend you to do a board level simulation to make sure that the signal integrity on the board design is good.
Altera Support
