LVDS Compatibility with GTS Refclk (CML / HCSL)
is there a way to find out what pin configurations and electrical considerations (e.g., termination, biasing) are required to ensure proper operation?
Just some general documentation to have a better overview of what is inside the fpga and what needs to be added externally, would be very helpful.
- Ash_R_Altera2 months ago
Please refer to the diagram in the following link showing the receiver buffer of Agilex 5 GTS. It shows Con-chip which is inside the FPGA and also Con-board, which user is supposed to put on the board.
As mentioned earlier, you may use the development kit as a reference. We recommend you to do a board level simulation to make sure that the signal integrity on the board design is good.
Altera Support
- Ash_R_Altera1 month ago
Kindly confirm whether the suggested steps have addressed your concern.
- sbj1 month ago
All good. Thank you
