14 years ago
JTAG error only when programming
I have a custom board with a MAXII CPLD (EPM2210F256), with the JTAG port built per the Handbook. With Quartus-II v. 9.1 and a ByteblasterMV cable I can ID the device, erase it, and blank-check it with no problem.
Only when I try to program it do I get the error: "can't access JTAG chain." I put an oscilloscope on the (4) JTAG signals and the power supply- all look very clean.
The data book says "Failures during in-system programming may occasionally be related to the Quartus II software" and says to look on the web site for details. I haven't found any there.
Can anyone shed any light on this or suggest other ideas to check?
Much appreciated...
    --- Quote Start ---
    My scope is 200MHz BW, 1Gsa/sec. If there are any glitches they are <10nsec wide and die out very fast.
    --- Quote End ---
    Ok, the scope sounds good enough. The fact that you do not see any glitches is a good sign.
    --- Quote Start ---
    Probably I will try the Terasic programmer (note Atlera lists their USB-Blaster for $300!). Also in proces of downloading the latest Quartus SW, so we'll see...
    --- Quote End ---
    Yeah, the Altera versions are way too pricey. The Terasic versions work great!
    Cheers,
    Dave
    Dave, thanks for your reply. My scope is 200MHz BW, 1Gsa/sec. If there are any glitches they are <10nsec wide and die out very fast.
    Thanks again.
    --- Quote Start ---
    --- Quote End ---
    What bandwidth is your scope? A low bandwidth ~50MHz scope might not show ringing and steps in the TCK signal due to transmission line reflections.
    --- Quote Start ---
    --- Quote End ---
    Try another ByteBlaster, or better yet, try a USB-Blaster. If you don't have one, Terasic sells them for $50. They work well.
    Cheers,
    Dave
